Author Topic: d.i.y. petrol-injector cleaning  (Read 1529 times)
vinny
  • Liverpool
« on: 10 September 2008, 21:52:59 »
hi all,
        is it possible to clean the petrol injectors at home? it could be powered by a small compressor, i`m sure i`ve seen some gizmo on an american website
Re: d.i.y. petrol-injector cleaning
« Reply #1 on: 10 September 2008, 21:53:56 »
hi all,
What makes you think they need cleaning?
« Reply #2 on: 10 September 2008, 22:54:57 »
Ideally you want to suspend them in an ultrasonic bath and exercise them by feeding pulses through the solenoids while they are cleaning. I would also rig up some means of observing the spray pattern and flow rate so you know if you've improved them. An old fuel pumnp and FPR, rail and a circuit to actuate the injectors. Ideally you want to find a fluid as a petrol substitute with a similar density but not quite as likely to turn your garage / shed, etc. into a fireball. :o
Perfectly do-able on a DIY basis but not sure it's worth setting up for a one-off job.
I've used these people before: http://www.injectorcleaning.co.uk/. Very good service. Injectors come back clean with a before and after report on flow rate and spray pattern. Rubber seals, finger filters and pintle caps replaced with new.
I went to the trouble of getting a second set of injectors to cover me while they were away. Needn't have bothered. The morning after I fitted them to the car the cleaned ones came back. They were away well under a week and I sent them bog standard first class post.
« Reply #3 on: 10 September 2008, 23:21:03 »
noticed today that my new workplace has several ultrasonic baths,and a couple of sandblasting cabinets  ;) :)
vinny
  • Liverpool
« Reply #4 on: 11 September 2008, 21:05:02 »
hello tunnie
                not sure they do need cleaning, car runs fine but has done 155k(40k is mine) i don`t know if they have ever been cleaned, anyway i just like to tinker!
        vinny
vinny
  • Liverpool
« Reply #5 on: 11 September 2008, 21:10:19 »
thanks for the info kevin & albitz
vinny
