Author Topic: What has P*ssed you off today?  (Read 3125548 times)
0 Members and 21 Guests are viewing this topic.
    • Grandland 1.5 diesel
Re: What has P*ssed you off today?
« Reply #1560 on: 26 March 2024, 15:24:27 »
Big difference between weathered and green slime. Out patios are York stone and now look like the year they were laid.
Bloody southerners, coming up here, pinching our stone.
Bloody Northerners coming down here and nicking our women... :P
Of course, how could they resist?  ;D
Diesel till I die
countrywoman
  • worcestershire
    • skoda yeti
« Reply #1561 on: 27 March 2024, 11:20:34 »
Bloody over slept again, put the radio alarm on and crashed back out. Must be the local BBC presenter!! and its raining again!!!
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #1562 on: 29 March 2024, 10:02:44 »
This - is it ever going to stop raining.
Unblocked scuttle drain and flushed out sludge (again). Might have to look at removing that rubber drain bung, but cant get my arms down past the pollen filter.
Omega 2.5 V6 Facelift Estate.
« Reply #1563 on: 29 March 2024, 11:15:13 »
If the drain is clear, given the age of all Omegas now, next step is to pull up the passenger carpet and prod the triangular-ish shaped bit of mild steel plate that covers where the steering column goes through on LHD models.  Most of these are probably in a bad state of corrosion now, especially if scuttle drains have been blocked.
If it has rusted through, only real option is some kind of repair, not easy given near zero access.  TBE's was a painted steel plate (with a bolt through it to allow pulling from inside) stuck to what remained with nearly an entire tube of sikaflex.  AFAIK, its still holding now, not that its moved 3 years!
« Reply #1564 on: 29 March 2024, 11:23:37 »
With the screen, scuttle and dash out, that panel can theoretically be replaced, it's bonded into a channel in the firewall.
This channel is what eventually leads to the rot as it collects dirt and debris that, in turn, holds moisture. The panel is only powder coated so it's not particularly protected.
Obviously noone is going to go to those lengths to fix the problem properly, so any repair, however well intended, is going to be a bit of a halfarsed bodge.
« Last Edit: 29 March 2024, 11:29:06 by Doctor Gollum »
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #1565 on: 29 March 2024, 15:14:58 »
The rain , started a project in the garden all going well up till 15.05 must convince the wife to move to the Carribbean..
« Reply #1566 on: 29 March 2024, 15:16:50 »
It rains almost every day there ;D
« Reply #1567 on: 30 March 2024, 00:14:57 »
sigh ...... bulkhead!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #1568 on: 30 March 2024, 01:18:14 »
The two terms aren't mutually exclusive.
« Reply #1569 on: 30 March 2024, 07:01:29 »
Stop talking out of your fanny.
Diesel till I die
« Reply #1570 on: 30 March 2024, 12:01:56 »
no they're not .... Americans have firewalls, wristpins, rocker panels etc etc etc ..... we have bulkheads, gudgeon pins & sills etc etc etc
« Reply #1571 on: 30 March 2024, 12:25:03 »
https://aviation.stackexchange.com/questions/78397/in-aircraft-construction-what-is-the-difference-between-a-firewall-and-a-bulkhe#:~:text=So%20in%20a%20nutshell%2C%20a,the%20rest%20of%20the%20plane.
Obviously that's wrong too presumably... ::)
« Reply #1572 on: 01 April 2024, 09:10:04 »
Are we talking cars or planes?
I'm away & don't have enough interweb to read it.
You can always find what you want to find if you look hard enough. What's the past tense of dive? Here in Blighty it's DIVED but if you Google it, it'll say you can also use DOVE .... It's not correct as far as I'm concerned but the Web says is OK  ::)
« Reply #1573 on: 01 April 2024, 11:37:09 »
Dove would have been my first choice... As in, "The pelican dove into the water.". "The pelican had dived into the water, but resurfaced fishless soon after." Is how I would use dived.
As for car planes or boats, it doesn't really matter... a firewall is one purpose of a bulkhead, pressure is another as is water.
A bulkhead is by definition a structural panel , usually vertical in orientation, and the preceding words ie fire resistant/proof; pressure resistant/tight; water tight etc indicate how the bulkhead is designed and engineered to perform. Ergo a firewall is a bulkhead that's designed to contain or slow a fire. Depending on how it is constructed and from what, it may serve more that one purpose.
On a ship, a watertight bulkhead may also be designated as a fire wall as it will have been designed as such, albeit a secondary requirement to being watertight... If a ship sinks because it flooded then having firewalls is a moot point. But equally if a bulkhead cannot contain a fire then it is unlikely to be watertight. And if a compartment floods the watertight bulkheads serve as pressure bulkheads as they have to resist the weight of the water behind them.
« Last Edit: 01 April 2024, 11:40:11 by Doctor Gollum »
« Reply #1574 on: 01 April 2024, 11:54:13 »
Pleaded and Pled. I don't like pled.
Diesel till I die
