What has P*ssed you off today?
Started by Varche, 02 January 2023, 18:25:56
Working on them day in day out, the 777 has the most space because it's the broadest cabin.
The 350 IS narrower than the 787. Sure the high ceilings and vertical sidewalls make the 350 seem spacious, but it's an illusion.
The 787 is only 2-3-2 in WT+ rather than 2-4-2 on the ironic*  Airbus. This actually makes the cabin more special on the 787. Not to mention much easier to work in. Both are 3-3-3  in WT Vs 3-4-3 on the 777 and previously the 747.
On the 787 you can turn a single trolley between the toilets in Economy, on the A350 you risk skinning your knuckles just going up the aisle with a trolley. And don't get me started on the config. Alot of crew either actively avoid the 350 or suffer it for the destinations it serves.
*I say ironic because it's labelled Xtra Wide Body. It isn't. Unless you compare it to the A320 family as a point of reference. Flight crews dislike it too because Airbus tried to make it fly like an A330... Which it isn't so it doesn't.
The A350 is best described as just enough... And that's not a compliment. Given free choice I wouldn't operate on it ever again and do actively avoid it.
I understand where you're coming from re the windows on the 787, and if someone asked, I would gladly unlock a window to allow free viewing. That said, on a night flight back to Blighty, one window will illuminate the whole cabin when the sun rises... And coming back from say, Seattle, mid summer, it basically doesn't get dark, which is sub optimal for a night flight, hence dimming the windows or dropping the blinds.
Tother thing of course with the 787 is that the windows are about 50% bigger so more light etc.
Quote from: YZ250 on 27 July 2025, 20:20:43
I'm pissed off because I kerbed an alloy as I was leaving Woolacombe car park.  >:(  This is the first alloy that I've ever kerbed so I'm seriously annoyed about it and want to cry.  ::)
Going to look back on old posts to see TB's wheel refurb place suggestion but I've told Mrs YZ that I'm never going back to Woolacombe.  ::)
I'll drop you a PM.
If they are diamond cut, that might be more of an issue.
I've only flown on a 787 twice, and found it comfortable enough for the flight over the atlantic.  Being a pauper, I'm never going to be turning left as I walk in a plane, scum class only for me.
What has got my goat up is clearly last weekend I must have loaned my car to that reprobate from Thame.  >:(
Quote from: ronnyd on 27 July 2025, 20:51:40
It's a bastard when a kerb leaps out and attacks your car.  ;)
I had a tree jump out in front of mine at the weekend, and I was going absolutely flat out at the time.
Viral_Jim
Quote from: TheBoy on 28 July 2025, 12:29:26
I didn't think this looked too bad, but the longer you look, the worse it gets  :(. Racing, or just c0cking about?
YZ250
Quote from: TheBoy on 28 July 2025, 09:42:49
I'll drop you a PM.
Thanks, and replied.  :y
YZ250
Quote from: TheBoy on 28 July 2025, 09:45:57
;D ;D
Oh dear, I'm guessing that if I'm getting the blame it must be something to do with speeding.  ::)  ;(
Raeturbo
Laying a rubber road.
Rangie
A white van, with a  thieving Eastern European couple touring around our area to see who's left their garage open or left something of any value outside, number given to police vehicle untaxed, suprise surprise.
If they've not taxed it, they've probably not registered it. Assuming that the reg is original to the vehicle in the first place.
Quote from: Viral_Jim on 28 July 2025, 14:14:25
The only damage was a broken top shock mount, rest was just reassembly as those steel ball joints go through the wheel hub from the other side ;D
Quote from: YZ250 on 28 July 2025, 23:31:09
;D ;D
I wasn't speeding, the limit was just too low  >:(
Poxy HS2 dragging out pointless roadworks, despite never, ever doing anything. Hence 2 years into this new bridge, and still another year to go!
Quote from: Rangie on 29 July 2025, 13:31:30
Yep, and my betting is that the Police will be "unable to trace" the owner of the vehicle, just like when one of the pikey ****s reversed into MRs. KW's car. Despite having his business card, photo, CCTV evidence, registration number, etc. They are above the law because the Police choose not to deal with them. >:(
Varche
Quote from: TheBoy on 29 July 2025, 16:13:12
;D ;D
If you were riding The Gravy Train, you would never want it to pull into a station!
