Headlight Range
Started by Lizzie Zoom, 08 January 2023, 14:17:15
Oops, should have read the whole thread.
LZ - as DG says, the first pic is the suspension level sensor (only fitted to Elites).  You have now found the correct ones, they are fitted in the same place on all Omegas fitted with HIDs (MFL MV6 and Elites, and FL MV6, CDX and Elites).
If your "fix" doesn't work long term, it should be possible to fabricate a new rod and ball joints.  And now you know which sensor and where it is, that makes life easier.
Lizzie Zoom
Quote from: TheBoyhighlight][/highlight] link=topic=150014.msg2018101#msg2018101 date=1673462467]
Indeed TB, although I hope my "repair" will last long enough for me not to revisit this ::) ;D ;D ;)
But yes, due to the advice, I can see what I could do for a more permanent fix  :)
Quote from: Lizzie Zoom on 11 January 2023, 18:59:15
I have the bits - ballstuds, plastic housings and LH/RH threaded rod - to make a new droplink if you're interested.
Raeturbo
Quote from: Lizzie Zoom on 11 January 2023, 09:19:23
Quote from: Raeturbo on 10 January 2023, 18:06:43
I've had headlight position warning on since I bought the car I ignore it as my lights appear to be ok anyway😎
But mine is due an MOT, so would this not amount to a "Failure" ?  How did you get around that please? ???
Sorry Lizz missed that, my mot guy has a dodgy eye on times👀👀🤭
Laying a rubber road.
Quote from: Raeturbo on 12 January 2023, 00:09:47
Because without a working sensor the headlights won't move. Which in turn means you can adjust them to pass an MOT**
** the MOT requirement is that they don't blind oncoming traffic, not that you can see where you going, so tweaking them down and to the left is usually good enough.
Aren't any MOTers now shitty on dash lights (granted on an Omega, the warning isn't on the dash binnacle)?
Lizzie Zoom
#51
Quote from: Nick W on 11 January 2023, 21:59:19
Indeed TB, although I hope my "repair" will last long enough for me not to revisit this ::) ;D ;D ;)  :-*
Yes please Nick :y :y
The part that is faulty is the fixing on the wishbone, and I suppose the drop link that must be worn.  But you know what I will need, thanks.
Please let me know how much I must send you and I will give you my address via PM. :-* :-*
Lizzie Zoom
Quote from: Nick W on 12 January 2023, 09:05:09
Thanks Raeturbo and Nick, now I understand. :y :y
Raeturbo
I was lucky enough to have had my headlight positioning paraphernalia fail in a range where the lights are not too high and not too low :y
