Bending a rod
Started by TheBoy, 09 January 2023, 10:56:05
biggriffin
Quote from: zirk on 15 January 2023, 13:38:12
I reckon the minute you put that on a Gas Hob the Ruler is just going to melt.
Mmm TB+Gas+flame=💥. Not again
Hoof'land storeman.
Quote from: biggriffin on 15 January 2023, 13:59:26
Turns out that it wasn't painted, but some sort of coating. Oops.
But bent, touched up, fitted to the car  :y
So c'mon then, what was it and what is it now?  ???  ::)
I'm guessing a cargo net, since that was mentioned in 'What have you done......." earlier.
Diesel till I die
Quote from: STEMO on 15 January 2023, 17:39:24
Ah, didn't spot that.  :y
I think we need the full story though...  ::)
As STEMO says, a small cargo net for the sides of the boot.  Only the manufacturer only makes them for the nearside, and she wanted one on the offside as well.
https://accessories.jaguar.com/gl/en/xe/interior/interior-protection/t4n7499-loadspace-side-net/#tertiary-tabs
I wonder if they offer one for the nearside, just not against that reg/chassis number. ::)
It's the sort of stuff that gets added as an 'improvement' over the previous model/lower specs.
Quote from: TheBoy on 15 January 2023, 18:36:21
For example  ;)
Quote from: Doctor Gollum on 15 January 2023, 20:36:30
For example  ;)
What are you on about?
Diesel till I die
Apparently unavailable boot net for the off side of a Jaguar XE.
Obviously. The link is pretty self explanatory  :D
The link looks like the same link Jaime posted to me. Same part number, same picture.
Diesel till I die
Quote from: STEMO on 15 January 2023, 22:06:51
Well there you go. Probably because it is the same link taken out of his post.  ;D
https://rimmerbros.com/Item--i-T4N7499 is what I meant to post...
It's for the offside, which is the one he was trying to 'make' unless he's gone and got nearside and off side confused.
Quote from: Doctor Gollum on 15 January 2023, 22:55:33
Not so self explanatory then  ::)
Diesel till I die
Quote from: STEMO on 15 January 2023, 23:28:36
And....not so sure about your second link. Same part number, same picture.
Diesel till I die
