Shagged battery or another cause?
Started by Field Marshal Dr. Opti, 13 January 2023, 14:55:26
Rangie
Quote from: Sir Tigger KC on 22 January 2023, 23:09:35
You people?  ::)
He's old like me so that allows you to say whatever you like.👍
Quote from: STEMO on 22 January 2023, 20:19:20
The battery on my Astra lasted seven years. I took my car to a garage, asked them to put a battery on it, gave them £70 and drove away. I have no idea what make of battery.
You people do make things more complicated than they need to be.
That's very true.
ronnyd
If we weren't so anal about our cars, we probably wouldn't be on here.  ???
Not sure how many A/H are needed to start a derv Astra.
£70 fitted sounds reasonable. It may be some budget brand but should still last longer than you will. ::)
The old Bosch battery had 680 CCA.....the new Exide 720 CCA which I presume is better.
Cold cranking amps?
Quote from: Field Marshal Dr. Opti on 23 January 2023, 13:21:56
£70 sounds about right for a Bosch Silver battery. Which is all that's needed on a daily driver.
Quote from: Field Marshal Dr. Opti on 23 January 2023, 13:29:28
Cold cranking amps?
Yes marginally better, basically means the internal resistance is a bit lower
Not that your application really needs mega cranking amps
Quote from: Rangie on 22 January 2023, 23:14:24
You people?  ::)
Ah OK, he's a patronising old git then?  ;D
Quote from: Sir Tigger KC on 23 January 2023, 18:47:34
You people?  ::)
And your point is?  :-\
Diesel till I die
Quote from: STEMO on 23 January 2023, 19:27:25
You people?  ::)
Do I need a point to call you a patronising old git?  :P
Quote from: Sir Tigger KC on 23 January 2023, 21:01:57
You people?  ::)
I am certainly not patronising. I am obnoxious, insulting and, possibly, flatulent, but not patronising  ;D
Diesel till I die
Quote from: STEMO on 23 January 2023, 21:15:43
You people?  ::)
OK point taken you old git!  :)
You people.......  ::)
Quote from: Doctor Gollum on 22 January 2023, 19:29:43
That's what you get from buying via Amazon.  :-X
In my experience of returning stuff to Amazon (proper, not Marketplace), as long as you don't go off script, they are very good at returns and refunds.  That said, the last return took a couple of weeks to be refunded, as the package got caught up in the RM strike.
Their slickness is what has helped them become the success they are.
