Author Topic: Ford Kuga PHEV  (Read 8586 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Ford Kuga PHEV
« on: 30 January 2023, 15:33:13 »
Trying to do my bit for the planet, I swapped my 7 year old 2.0l petrol Mondeo, which has been absolutely faultless, I’ve only paid for service items, for a 1 year old, 6k, Kuga PHEV, and would like to test the batteries, can anyone recommend an OBD tester which will work on these cars?
Apologies wrong section, admins please move to Gen car chat.
« Last Edit: 30 January 2023, 15:42:25 by Shackeng »
Re: Ford Kuga PHEV
« Reply #1 on: 30 January 2023, 15:54:47 »
Moving to the general car chat area
I would be getting plenty of Gaffer tape, Kugas leak water into the cabin like the preverbial and from bloody everywhere, just been diaging one at work for a collegue, in this case it was the sealent around the slam panel to boot floor interface being crap, and you can see similar all over the car (and when you search for common water leaks, you get that many potential sources!).
As for reading the PHEV battery parameters, it needs quite a specialist tool to access it sadly
« Last Edit: 30 January 2023, 15:59:43 by Marks DTM Calib »
Shackeng
  • Ramsbury
Re: Ford Kuga PHEV
« Reply #2 on: 30 January 2023, 16:01:45 »
Any other good news Mark? I’ve seen the one on here https://www.youtube.com/watch?v=89Zq_015Yrg  at £80 and was hoping to get one that works cheaper.
« Last Edit: 30 January 2023, 16:07:38 by Shackeng »
Re: Ford Kuga PHEV
« Reply #3 on: 30 January 2023, 16:47:24 »
Right, had a chat to one of my guys who is Ex Ford Brasil.
He pointed me at this;
https://forscan.org/forum/index.php?sid=7b2d5ae121b386ee9d2af7d12dfa05ca
Which is similar to "My Naff Code Reader" but with much more support
As for the water ingress, some areas to check in this list: https://www.google.com/search?q=kuga+water+leaks+site:www.kugaownersclub.co.uk&rlz=1C1GCEB_enGB983GB983&sa=X&ved=2ahUKEwje-NrG3-_8AhVUg1wKHfjiALUQrQIoBHoECA0QBQ&biw=1440&bih=740&dpr=1.25
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Ford Kuga PHEV
« Reply #4 on: 30 January 2023, 17:27:53 »
I looked into Fraud Kuga Diagnostics etc (the outlaws have a 2019 tractor juice version)
I got a Forscan dongle in the end  :y
plenty of versions  of dongle (OBD2 plug) ,I got the one that switches between high and low canbus .
you have to get an authorisation code (pretty simple) and there are (basic) free and in depth paid for versions of he software  .
fortunately ,other than a new battery(needed the car told) nothing has gone wrong YET  :-X  :P  :D
Re: Ford Kuga PHEV
« Reply #5 on: 30 January 2023, 18:58:17 »
I have a Forskin dongle somewhere with a switch I installed to go between hi / low BUS. If it helps you, I can try and dig it out :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Ford Kuga PHEV
« Reply #6 on: 30 January 2023, 19:58:58 »
:o
It's not that type of forum  :D
Re: Ford Kuga PHEV
« Reply #7 on: 30 January 2023, 20:35:07 »
:o
;D ;D
Re: Ford Kuga PHEV
« Reply #8 on: 30 January 2023, 21:11:39 »
I have a Forskin dangle somewhere............ :y
Really?  :o  ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Ford Kuga PHEV
« Reply #9 on: 30 January 2023, 21:22:33 »
:o
Are you sure, or do you just not read Opti's posts? 8)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Ford Kuga PHEV
« Reply #10 on: 30 January 2023, 21:32:08 »
:o
I do read most of the posts on OOF  ;)
BUT ....
 I have filters between my eyes and brain that block some content  :D
Shackeng
  • Ramsbury
Re: Ford Kuga PHEV
« Reply #11 on: 31 January 2023, 07:25:09 »
Thanks James, I get the impression that these are ‘badge’ programmed. Will this work on a Ford?
Shackeng
  • Ramsbury
Re: Ford Kuga PHEV
« Reply #12 on: 31 January 2023, 07:32:46 »
Thanks Mark
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Ford Kuga PHEV
« Reply #13 on: 31 January 2023, 13:16:43 »
I think there is a minor operation that can fix that.  :y
