Author Topic: Dry white smoke.  (Read 10070 times)
Re: Dry white smoke.
« Reply #15 on: 21 February 2023, 22:21:41 »
Also a hint as to make, model and engine wouldn't go amiss  ;)
It's an Alabama Mumsy Bus.  Didn't you know?  ;D
It isn't as it happens  ;D
Ah... So if you buy it, what will you call it?  Old Smokey?  ;D
« Reply #16 on: 21 February 2023, 22:23:35 »
The Dolly Trolley... :D
Although, at 270ish bhp, that might be a touch satirical  :-\
« Last Edit: 21 February 2023, 22:25:56 by Doctor Gollum »
« Reply #17 on: 21 February 2023, 23:37:53 »
Or Dolly the Trolley.  :y
Could you get in the back of one of those with a Trolly Dolly?  ???  :D
« Reply #18 on: 22 February 2023, 00:03:02 »
If I buy it, I will be sure to let you know ;)
« Reply #19 on: 22 February 2023, 02:00:43 »
Yes please. None of this A gentleman never tells bollix!  ;D
« Reply #20 on: 22 February 2023, 05:10:13 »
Obviously it doesn't quite have the same amount of room for activities as the Alabama Mumsybus...
« Reply #21 on: 22 February 2023, 09:46:19 »
Cant see it being stuck rings, that only occurs due to carbon deposits or corrosion, you dont stop an engine which is operating ok (and if it was carbon it wouldn't have been ok) and then this suddenly happens unless water is getting in somewhere and then they smoke a good heavy blue tint.
White smoke is, and can only be, water from some source, that might be coolant but, could equally be a wet inlet or a wet exhaust.
« Reply #22 on: 22 February 2023, 10:39:17 »
That's reassuring :y The fact it is clearing during the second viewing certainly points to the latter of the two.
« Reply #23 on: 22 February 2023, 11:06:04 »
Also, am I right in thinking that Bank 2 Sensor 1 is down stream of the cat, ie the rear most sensor :-\
« Reply #24 on: 22 February 2023, 11:09:40 »
Nope, sensor 1 is always the primary mixture control sensor, any higher numbers are emmission monitoring sensors (e.g. post cat)
« Reply #25 on: 22 February 2023, 11:14:17 »
So it's between the manifold and cat?
« Reply #26 on: 22 February 2023, 11:17:58 »
Yep, well, inbetween the head and cat as some setups fix the sensor into the combined channel at the exit of the manifold
« Reply #27 on: 22 February 2023, 11:36:00 »
That makes sense. Thanks Mark :y
