Author Topic: Thanks, Mr Chrisgixer!  (Read 10173 times)
« on: 10 April 2023, 09:08:35 »
I got in a bit of a mess doing rear pads yesterday.  I followed the process to put the handbrake in the service position not using the diags tool, which going by the noises, seemed to retract the handbrake, but no messages that it had actually done it.
Tooke the pads out, but couldn't push or wind the piston in, so got the diags tool out to use that to put handbrake into service position.  Unfortunately, just turning the ignition on was enough to cause the handbrake to come on, popping the piston out of the caliper in the process.
Fortunately that nice ex-member Gixer popped over to lend a hand at this point to see what could be done.
4 hrs later, we had managed to get 70 ball bearings and 10 springs back in to the handbrake actuator, and rebuilt that.  Tidied the caliper enough so it is short term usable (it's had water ingress and corroded badly, so needs refurb, looks like it had been binding as well (probably just replace it TBH)), and got it back together.  Car is movable now, and probably fine for short journeys, as I imagine we'll be hard pressed to get another caliper by next weekend, given the short week.  Need to give it a quick test drive.
Had a very quick look (it was not far off getting dark at this point) at other caliper on the other side, that looks badly corroded, but might be serviceable, half tempted to get a caliper for that side as well.
I'd like to thank chrisgixer for popping over yesterday to lend a hand, as it had seemed like a completely lost cause at one point when bearings and springs flew everywhere.
Re: Thanks, Mr Chrisgixer!
« Reply #1 on: 10 April 2023, 09:40:23 »
What a PITA!
Yeah, there's a bit of a knack to getting it into service mode but you do get a warning on the dash when successful.
« Reply #2 on: 10 April 2023, 11:26:29 »
What a PITA!
Its kinda blessing in disguise, as I wouldn't have known how must corrosion was behind the dust seal.
I shall stick to using SDD to put it into service mode.  Bit of a pain, as its one of those SSD procedures that insists the battery voltage is high, so need to start plugging in power supplies to it.
  • Online Online
    • Grandland 1.5 diesel
« Reply #3 on: 10 April 2023, 11:51:10 »
Well done Gixer  :-*
Diesel till I die
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 10 April 2023, 12:21:31 »
Glad you and Mr Gixer managed to sort it between you.  :y  I have service mode on mine to do the rears but as I’m rather attached to my fingers I prefer to connect the battery charger and use VAGCom to keep the pistons retracted. As my start button is on the centre console I cover it to prevent accidentally leaning on it. I’ve already made that mistake once when I had the MMI in my hand while checking the shark fin nav/phone aerial cable and accidentally leaned across on to the start button, which turned the ignition on with nothing connected. Luckily I got away with it.  :-[
Anyway, hope it holds out for you.  :y
« Reply #5 on: 13 April 2023, 14:31:38 »
Well done Gixer  :-*
Yes....but why is he an Ex-member. Did you upset him?....or is it just me you annoy. ;D
  • Online Online
« Reply #6 on: 13 April 2023, 14:53:36 »
Well done Gixer  :-*
We had some interesting discussions, that's all.
Diesel till I die
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #7 on: 13 April 2023, 17:45:33 »
I wonder if his MV8 ever got finished ?  :-\
« Reply #8 on: 16 April 2023, 10:53:51 »
And yesterday I drove it over to chrisgixer's gaff (my driveway doesn't really allow for jacking up both sides at the same time if the neighbours are in) to fit a pair of new calipers to the back of it.  Obviously not before the ever lovely Mrs chrisgixer cooked us breakfast ;D
Thanks chrisgixer :y
« Reply #9 on: 16 April 2023, 10:54:22 »
Errr, "progressing" rather than finished  ;D
Migv6 le Frog Fan
« Reply #10 on: 16 April 2023, 13:14:06 »
Cant rush a good job. ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #11 on: 19 April 2023, 12:33:25 »
Chrisgixer
That's a name from the past
Hope hope life's treating you well Chris  :)
« Reply #12 on: 19 April 2023, 14:42:59 »
Chrisgixer
I could comment .... but won't  :-X
  • Online Online
« Reply #13 on: 19 April 2023, 14:46:28 »
Chrisgixer
You just did.
Diesel till I die
« Reply #14 on: 19 April 2023, 15:51:31 »
Chrisgixer
You just did.
I know  ::) ;)
