Author Topic: Thanks, Mr Chrisgixer!  (Read 10154 times)
Re: Thanks, Mr Chrisgixer!
« Reply #15 on: 19 April 2023, 19:48:49 »
.. and right on cue, the XE's rear pads started making a grinding noise today. Outside pads have reasonable meat on them so a stuck caliper or rusty back of the disk, I suspect.
    • Grandland 1.5 diesel
« Reply #16 on: 19 April 2023, 20:21:49 »
I heard that noise from the rear on the A169 Whitby Road last week. Coming down a steep hill at 60mph with a less than 90° bend at the bottom.  ;D I had to remain calm and assure the wife that it was nothing serious, just a stone......or something. Managed to get it home with anticipation, keeping my distance, judicious use of the gears and braking ever so gently so as to just use the front brakes.
Garage said there was absolutely nothing left on the nearside rear pads, and not that much anywhere else. Pads on all corners, £198, and off we went.
Diesel till I die
« Reply #17 on: 19 April 2023, 20:27:36 »
More than these?  ::) (pretty sure these were off the back of my Omega )
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18 on: 19 April 2023, 20:59:49 »
Not Omega rears, look likw astra G front pads  :-\
« Reply #19 on: 19 April 2023, 22:00:12 »
Might be then ... I did have an Astra G at one time.
I know that I replaced the rear pads of my Omega once when there was next to F*** all lining left.  :-[
« Reply #20 on: 20 April 2023, 09:38:15 »
OSR inboard pad should have a sensor.
Calipers are the pretty standard ATE setup, where the slider pin gets exposed when the pads wear.  And being ATE, non standard allen size, 7mm I think for the rears - but I'm sure you'll have 7 and 9mm allens sockets for just such an occasion.
« Reply #21 on: 20 April 2023, 09:39:29 »
Loads left on them, whats wrong with you ;D
« Reply #22 on: 20 April 2023, 09:44:28 »
 ;D ;D ;D
« Reply #23 on: 20 April 2023, 11:31:12 »
 ;D ;D ;D
No, no, no.  This is whats called getting your money's worth...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #24 on: 20 April 2023, 12:01:13 »
Chrisgixer
That's a name from the past
Hope hope life's treating you well Chris  :)
I could comment .... but won't  :-X
Come on then, don't tease .......
« Reply #25 on: 20 April 2023, 12:13:50 »
Chrisgixer
You'd have to ask Chris because I hadn't a clue what I was supposed to have done  :-\ :-\
