Author Topic: Blowing exhaust - MoT failure?  (Read 3024 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« on: 12 September 2008, 21:50:20 »
...if it's not due to corrosion?
Have just gone to re-tax wifey's Mini (the one with OOF registration) and the MoT has expired!!  It's done about 150 miles since the last one and is bodily sound, but I know the exhaust blows a bit from the manifold joint (like all Mini's do).  Is this a failure?
Off working abroad on Wednesday and she needs her car...so i need to MoT it quickly!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Blowing exhaust - MoT failure?
« Reply #1 on: 12 September 2008, 21:55:34 »
Not a failure on its own. ...
But, if an exhaust is insecure, or shows a visable hole it may fail.
It may also increae emissions, which in turn will fail it.
Doubt a manifold will cause either of the above.
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #2 on: 12 September 2008, 21:59:16 »
not quite true
it all depends how bad the blow/leak is if the tester thinks its excessive it will fail if its only a minor leak it will pass.
lee
philhoward
  • Staffs
« Reply #3 on: 12 September 2008, 21:59:17 »
It's secure enough and was brand new last year.
It's a pre-cat car (1990), so emmissions should be a doddle - since i fixed the carb!
Markie
« Reply #4 on: 12 September 2008, 22:01:47 »
not quite true
lee
Diagnosis based on OPs use of term " blows a bit..." :y
philhoward
  • Staffs
« Reply #5 on: 12 September 2008, 22:03:49 »
You can feel it by hand and only really hear it when giving it some beans...
lee4206
  • southampton
  • Mot Tester
« Reply #6 on: 12 September 2008, 22:13:29 »
  [quote]Diagnosis based on OPs use of term " blows a bit..."  [/quote]
fair do's
philhoward
Cant you just replace the clamp or seal it well enough to get through the test?    If its not that bad i wouldn't worry about it but it does depend on the tester.
« Reply #7 on: 12 September 2008, 22:41:18 »
In which case it should be fine... They don't really give it the beans for an MOT test :y :y :y
« Reply #8 on: 12 September 2008, 22:42:25 »
Our Mitsubishi passed last year with a 'bit of a blow' didn't expect it too. faild this year, till garage did a bit of a job on it.... ;D
Don't want to spend much money on this, was hoping it would fail big time ::) swmbo drives is, she is supposed to drive the Mig, sat on the drive.. ::) ::) ::)  Need to get her out of the Mitsubishi to slow her down a bit. :-X
« Last Edit: 12 September 2008, 22:42:58 by floodm »
