Author Topic: Anyone on here got an Astra K auto?  (Read 8948 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 08 June 2023, 12:42:39 »
We've got 2.
Intermittently both cars fail to engage park properly, so you cannot remove key from the ignition.
With the ignition switched on and moving the gear leaver backwards and forwards it eventually releases the key.
I've searched for a solution (seems like a common problem) but results don't seem to offer a satisfactory cure.
Any ideas please?
Vauxhall deny any knowledge of the fault - surprise surprise!
I like red cars
    • Grandland 1.5 diesel
Re: Anyone on here got an Astra K auto?
« Reply #1 on: 08 June 2023, 14:44:35 »
Wifey's Astra K is auto, on a 66 plate, 58,000 miles. No problems like that, Barry.
Diesel till I die
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #2 on: 08 June 2023, 17:18:58 »
Hmmm, it's funny it's happening on both our cars.
Can't be a coincidence.
I like red cars
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 08 June 2023, 17:36:50 »
have the cars been left in the hot sun recently  :-\
Vauxhall ignition barrels   have a habit of sticking in when you pull the key out
the center section should spring out slightly
assuming it's a standard old style metal key  :-\
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #4 on: 08 June 2023, 18:55:29 »
It's nothing to do with the ignition barrel Dave, it's to do with the gear change not always triggering the park sensor.
I like red cars
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 08 June 2023, 19:49:59 »
Is the gear selector not linked to the ignition barrel (so you can't remove the key unless it's on P ) like the Omega set up  :-\
« Reply #6 on: 08 June 2023, 19:54:20 »
It is, Dave, yes. But a fault with the ignition barrel wouldn't release the key after the gear selector had been 'wiggled'.
Diesel till I die
« Reply #7 on: 08 June 2023, 23:16:40 »
Perhaps not on an electrical set up but a mechanical one might...
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 09 June 2023, 13:02:17 »
Well, I won't be doing that again.
Took the cover off the the gear selector, can't see bugger all underneath it.
Clipped it back on, selector wouldn't come out of park!
Took the cover back off, wiggled the selector, eventually it came out of park.
Put the cover back on and it seem to select OK now.
Bloody cars!
Nothing like the Omega set up in there :'(
« Last Edit: 09 June 2023, 13:04:31 by Auto Addict »
I like red cars
« Reply #9 on: 09 June 2023, 14:41:49 »
Bloody cars!
When you put the cover back on, and the lever stuck in park, did a little bit of poo come out?  ;D
Diesel till I die
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #10 on: 09 June 2023, 18:01:23 »
Bloody cars!
 ;D ;D
I like red cars
Page created in 0.03 seconds with 20 queries.
