Author Topic: Stripped bolt into plastic - fix?  (Read 5129 times)
Viral_Jim
  • Telford
    • Too many, mostly broken
« on: 09 June 2023, 12:20:23 »
The handle on our pressure washer is held in place with two bolts which, I now know are threaded straight into part of the plastic chassis of the washer.
I picked it up yesterday and was left holding only the handle as the bolts have stripped the plastic from the inside of their threaded holes.  ::)
I was going to araldite them back in but thought I would consult the collective "intelligence" of the OOF for a potentially better solution. I've seen that two part steel stuff at the motorfactors (no idea what its called), but any advice is welcome.
Thanks all  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Stripped bolt into plastic - fix?
« Reply #1 on: 09 June 2023, 13:35:39 »
The breakage has exposed the practical weakness in the design. Gluing it back together won't fix that, and is likely to be even weaker than original. That's even more likely when you consider that gluing plastic isn't as straightforward as it looks.
Is there space for a metal plate with captive threads? That's my preferred method for fixing such problems, as any glue used is just to hold the plate in place to enable assembly.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 11 June 2023, 10:20:40 »
Thanks all  :y
Bigger bolts to cut new thread into the plastic,not ideal but at least as good as the original
other rides
« Reply #3 on: 12 June 2023, 08:38:19 »
« Reply #4 on: 12 June 2023, 13:48:11 »
Thanks all  :y
Really.... ;D ;D
Viral_Jim
  • Telford
« Reply #5 on: 14 June 2023, 18:13:33 »
Really.... ;D ;D
I know, desperation stakes right!
Thanks AndyB, I got a pack of these and they did the trick. How long for, who knows?! But it's good for now  :)
« Reply #6 on: 14 June 2023, 18:26:29 »
Really.... ;D ;D
 :y :y
