Pages: 1 2 [3]  All   Go Down
Author Topic: Zafira B airbag light  (Read 14109 times)
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: Zafira B airbag light
« Reply #30 on: 21 June 2023, 13:01:55 »
So, further multi-meter led diagnosis has been done and I am now as sure as I can be that its the rotary connector.  Today I have:
  • Removed airbag unit, steering wheel and associated shrouds/trim
  • Cleaned all contacts that were readily aaccessible
  • Checked resistance to ECU from airbag plugs (results within 0.1 ohm of what the diagnostic computer states with airbag connected)
  • Partial reassembly (left off shrouds)
So I can rule out the airbag as the issue on this basis. I have come back to the rotary connector as, looking at live resistance data while turning the wheel, resistance on the circuits seems to fluctuate between 2ohm and 5ohm, suggesting the fault lies there. I should have applied this test last time around, but I forgot that the data was live rather than a snapshot  ::).
A used replacement CIM has been ordered for £25 (new/refurbished ones are £250plus  :o). I will report further on progress.  :y
« Last Edit: 21 June 2023, 13:05:36 by Viral_Jim »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #31 on: 21 June 2023, 17:06:09 »
do you have your "car pass" with the unlock code for the ECU  :-\
IIRC Astra H CIMs are coded to the car ,along with many other modules ,fuse box etc
Also not sure if a replacement CIM has to be divorced before fitting  :(
Viral_Jim
  • Telford
« Reply #32 on: 21 June 2023, 18:19:23 »
So, this one had been 'divorced' ready to fit.
BUT, to save on coding costs, according to an astra H forum (same part number) you can disassemble the CIM, change the rotary connector and build it back up retaining the part of the CIM that pairs to the car.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #33 on: 21 June 2023, 19:22:02 »
That's hood then  :)
good luck with it
Viral_Jim
  • Telford
« Reply #34 on: 24 June 2023, 20:15:57 »
Finally got an hour this morning to have a play about.
I'm pleased to say that it was pretty straightforward to split the upper and lower parts of the CIM. The 'lid' does indeed contain the rotary connector and basically not a lot else. I was able to swap this over onto my CIM and reinstall with no complaints from the car.
So far so good after a test drive. Its second hand so it's lifespan is obviously unknown, but at £23 delivered its a cheap enough fix.
Thanks for the help all  :y
    • Grandland 1.5 diesel
« Reply #35 on: 24 June 2023, 22:22:48 »
It's good when something works out like that  :y
Diesel till I die
« Reply #36 on: 25 June 2023, 10:58:53 »
Great news.  And even if it doesn't last the life of the car, you'll know where to look first :y
Pages: 1 2 [3]  All   Go Up
