car cd players
Started by raywilb, 07 July 2023, 21:49:19
Quote from: Andy B on 08 July 2023, 19:44:33
Quote from: Doctor Gollum on 08 July 2023, 09:25:47
That sounds like a lot of faffing around when you can simply put a CD in or play Spotify though the 3.5mm aux input from your phone headphone socket.
Where's that? No 3.5mm socket on my Samsung  ;)
No headphone socket  ???
That's a bit pants.
YZ250
Quote from: Doctor Gollum on 08 July 2023, 20:25:53
That's a bit pants.
Manufacturers started to drop the jack plug socket on flagship mobiles around 2016 onwards, hence the wireless Apple AirPods and Samsungs Ear Buds.  :y
Quote from: YZ250 on 08 July 2023, 20:46:14
That's a bit pants.
:y :y
That's a bit pants.
One less hole to allow the ingress of water. You can buy a USB C to phono adapter though
Yep, no 3.5mm jack on my iPhone 11. It's the same kind of thing for the car, though. Lightning lead from phone to car USB and anything that's on the phone is now available in the car, including Google maps.
Diesel till I die
My brand new Xperia 1 V has a headphone socket :-X
Quote from: Andy B on 08 July 2023, 20:55:50
That's a bit pants.
How do you charge it then >:D
ronnyd
Quote from: Doctor Gollum on 08 July 2023, 22:23:53
That's a bit pants.
Charging pad perhaps?  ???
Quote from: ronnyd on 08 July 2023, 22:44:47
That's a bit pants.
Mine can do that, whilst charging your phone and still let me plug my headphones in :D
It won't fold in half though, although I don't see that as a negative :y
That's a bit pants.
Primary reason is that you no longer need an audio quality Analogue to Digital converter, all audio channels are then digital and easier/cheaper to handle
CD players got ditched as nobody wanted them anymore, demand dropped like a stone, and no suppliers would make an automotive spec player so even if you wanted to fit one, you could not source one.
In their last days they were a USB device hung of a USB hub either in the head unit, or in the user interface panel but, now no more.
Actually, my suggested solution doesn't require a 3.5mm jack at all as it connects inline to the car aerial line.
Which raises a different question... What type of aerial fittings do Citroen currently use :-\
Quote from: Marks DTM Calib on 10 July 2023, 12:38:02
Fakra
Ta michly :y
Means a suitable pair of adaptors will be readily available  8)
Diesel till I die
