TB's buggered motor
Started by TheBoy, 12 July 2023, 16:07:01
Quote from: TheBoy on 12 July 2023, 19:25:49
If I do DIY, have to decide if the genuine part is better quality than pattern.
Genuine part looks to be about £300, including the gasket and bolts.
Britpart pattern looks to be around £130ish.
Won't be buying a Ching Chong special from egay, as it really looks a shit to change, and only want to do it once.
I wouldn't consider anything other than genuine or the OEM personally.
Raeturbo
Happened to my sons too, although after it was mapped decat, de dpf etc. apparently the replacement ones are strengthened
Laying a rubber road.
Quote from: VXL V6 on 12 July 2023, 21:57:28
I wouldn't consider that a big enough saving if it's as bad a job as it looks. Especially as it's a work car.
The Britpart one is probably the Ebay cheapie in a prettier box.
Raeturbo
His cost £650 per side all in.
Quote from: Raeturbo on 12 July 2023, 22:07:42
Was that a while back, as looks like part price (for genuine) has crept up in last few years...
Raeturbo
That was 18 months ago at mistermatic a Jag specialist in Swansea very good service 👍 they went at different times so I dare say it would have been better to have changed both whilst there, would have been cheaper
Quote from: Raeturbo on 13 July 2023, 08:12:10
The general consensus is to do both together, but from what I can see, the only commonality is the throttle body, which is about a 15-20 min job....
Currently neck and neck between the DIY repair and the burn it (I voted for burning)....
Get on with the DIY, it does not look that bad a job, plus the XJ is a much nicer drive and place to be than a Merc  ;D
Quote from: Marks DTM Calib on 13 July 2023, 08:25:45
I'd hate to see your idea of a tricky job !
Quote from: TheBoy on 13 July 2023, 08:35:57
Is it easier than a clutch on a modern front wheel drive, is it easier then welding cills on a rotten Ford, is it easier than a V6 head gasket change, is it easier than spark plugs on a smart car, I would say yes, its just unboting bits to get to them  ;D
You make it sound easy.  You know you will get lots of phone calls if I am daft enough to attempt this  ;D
Quote from: Marks DTM Calib on 13 July 2023, 10:56:21....
is it easier than spark plugs on a smart car,  ....
That depends on which Smart  ::)
The 450/452 cars with the 6 spark plug engine is a bugger as all the back end has to come off to do the lower 3
however ..... the 451 cars with the Mitsubishi engine is no more difficult than any other car ..... they're right there at the back ... coil per plug.  :y :y :y
Quote from: TheBoy on 13 July 2023, 11:15:58
What could possibly go wrong!  ::) ::)
If you do decide to torch if for the insurance park it next to a caravan or two. >:D
Seriously though, what Mark says. :y.....he seems to know a thing or two about cars. :)
