Pages: 1 2 3 4 5 6 [7]   Go Down
Author Topic: ABS-light constantly on after replacing front ABS/wheel speed sensors  (Read 44496 times)
Enceladus
  • London
Not to mention that the signal from the Carlton seems to be less noisy than the OP is getting.
« Last Edit: 30 October 2023, 16:05:23 by Enceladus »
LC0112G
Once you get the bit between your teeth, Malcolm......... ;D ;D
The question occasionally crops up in 'another place', and now I've got something to beat the non-believers over the head with ;D
bkorven
  • Sweden
    • '98 Omega B 2.0 16V
Thank you for your input and measurements, LC0112G!
It's so nice to have a benchmark, and to have ones suspicions confirmed. Your signal is significantly stronger.
bkorven
  • Sweden
Re: ABS-light constantly on after replacing front ABS/wheel speed sensors
« Reply #93 on: 08 November 2023, 23:33:13 »
This will be the final update, an end to it all.
The steering knuckles arrived, and were installed tonight. Look below for the result!
1.220 V @ 76 Hz (~1.6 revolutions / sec). For comparisson, I previously managed to get about 30mV at that speed with the other sensors.
I'm a bit surprised, the voltage is even higher than I was hoping for. Regardless, the signal is super clean and the ABS is working flawlessly. Case closed. FINALLY!
Conclusion: Avoid shady beer-named brands for sensors. And do not expect to be able to remove ABS-sensors.
Thank you all for helping me out!
Pages: 1 2 3 4 5 6 [7]   Go Up
