Main dealer code read
Started by STEMO, 07 August 2023, 12:56:13
Can't say i've ever used a dealer to read codes, just buy the dealer diags, or as a minimum use a generic OBDII app and a bluetooth OBDII dongle.
Understandable to use a dealer if you don't understand / have access too the diags though, but at that price it would have paid for itself in most cases.
Quote from: VXL V6 on 07 August 2023, 19:58:04
Yeah, but if you need the dealer to do the work, they won't accept your diagnosis.
Diesel till I die
They read the codes whether you ask them to or not. They have to otherwise everyone could turn around and blame them if it came back.
The total con, as Alf Garnet calls it, is that the starting point of fixing a fault code seems to be 'Replace the sensor' rather than to diagnose the live data.
MB want to charge you you diagnose a fault whether it's for a fault code or a dodgy mechanical fault
Quote from: Andy B on 07 August 2023, 22:00:12
Not unreasonable as diagnosis takes time and equipment. They make their profit changing oil... It takes longer for the customer interaction than the actual job.
