Author Topic: Valve stem seals  (Read 13143 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Valve stem seals
« on: 15 August 2023, 23:05:03 »
Does anyone know the cost of replacing valve stem seals. I assume that's what's wrong. Car has been stood a while, and after fitting the crank sensor, I started it, gave it a bit of welly (stationary) and had a large blue cloud. Tell how bad it was, my grandson came round and said.. 'Have you started the Omega?'....I said 'Why'.......he said..'There is a big blue cloud out in Humphries Drive'  ;D ;D ;D. Are there additives you can use to refurbish the seals that work. Engine has only done 80k and gentle driving (not thrashed) I am only the second owner, and had it donkeys years.
I don't really want to spend a fortune on engine stripping yet, as I am in the middle of sorting the bonnet and roof for respray (I shall do this myself, but it costs £250 per day for spray booth hire/usage)  :o
Re: Valve stem seals
« Reply #1 on: 15 August 2023, 23:21:48 »
With a couple of quick oil changes and use, they should come around.  ;) Another reason why being sat for ages isn't great for cars.
Any top end rattle is a sign that the lifters have drained down too, again nothing that some use will help resolve ;)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #2 on: 15 August 2023, 23:30:57 »
Cheers Al. Although it hasn't moved for ages, it has been started (when the crank sensor allowed) but the sensor gave up the ghost totally a few days ago, so had to change it.  :y
« Reply #3 on: 15 August 2023, 23:41:48 »
Valve stem seals  can be changed without head removal on some engines .... no idea of the inline 4s or V6s  :-\
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #4 on: 16 August 2023, 10:45:00 »
Yes, I have heard that Andy....but beyond my scope.
Has anyone got an idea of replacement price, if it ends up needing it
« Reply #5 on: 16 August 2023, 12:58:56 »
I know the earlier 2.6 was prone to stem seals, fixed I believe on the later ones.
No idea on costs, imagine its all labour TBH.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #6 on: 16 August 2023, 13:10:21 »
I think you are right TB....I have seen the seals for just a few quid. We will see how it goes, then it might be a call to Serek.  :y
« Reply #7 on: 16 August 2023, 19:26:06 »
Just in the process of doing mine, along with other jobs. Not a bad job to do at all :y
« Reply #8 on: 17 August 2023, 11:34:55 »
I assume cams out, but can it be done without removing head?
« Reply #9 on: 17 August 2023, 11:38:36 »
With a compressor and a spark plug adapter it should be doable. Assuming that the valve seats are clean and undamaged  :-\
Just make sure that the crank is securely locked to prevent rotation and may as well throw in a new timing belt and camcover gaskets whilst you are in there.
    • 530D M Sport, 330i Coupe
« Reply #10 on: 17 August 2023, 19:09:56 »
Wasn't fixed on the 03 2.6 I had, was only fixed when a lorry wrote it off and I bought 2x 3.2's with the insurance money and transferred the good parts  ;D
« Reply #11 on: 17 August 2023, 20:13:27 »
With a compressor and a spark plug adapter it should be doable.  .....
I used a length of string down the bore when I did my Dad's MKII Granada .. but it had simple tappets that easily unbolted to access the valves' springs
« Reply #12 on: 18 August 2023, 13:55:50 »
I personally have the heads removed, because the car had a cambelt let go, and all 12 inlet valves are as bent as a 9 bob note  ;D
I would do it head-off, personally. It gives the opportunity to inspect the valve seats, re-lap the valves, etc. I appreciate it's more work, but, I really wouldn't fancy dropping one of those little retaining collets down into an oilway or similar  :y
« Reply #13 on: 18 August 2023, 18:26:34 »
Terbs, you're on your own with that one. I aint removing heads ;D
« Reply #14 on: 18 August 2023, 18:58:00 »
If you want them done, I will do them for a very fair price. To include a full head refurb. I’m afraid I can’t do a job of that magnitude for totally free, but it would still be a fraction of garage labour…. It would also be prime time to do cambelt and water pump - it would be removed regardless, so no extra labour ….
The only caveat is that I can’t work at the speed I used to - I’d need the car at my place for a short while :y
« Last Edit: 18 August 2023, 19:00:01 by JamesV6CDX »
