Insignia Cdti,
Started by tooleater, 19 August 2023, 10:27:56
Quote from: Kevin Wood on 20 August 2023, 10:17:29
One of my colleagues has an Insignia the same age and mileage as my jag.  I reckon he has a major "standing by the roadside"  breakdown about every 6 weeks. Vauxhakls clearly aren't what they were.
Neither Vauxhall nor Jaguar are high in the rankings
Reliability by brand for cars up to five years old
Rank   Brand   Score
1.   Lexus    98.4%
2.   Toyota   97.2%
=3.   Mini    97.0%
=3.   Mitsubishi   97.0%
=5.   Hyundai   95.8%
=5.   Suzuki   95.8%
7.   Kia   95.5%
8.   Mazda   95.2%
9.   MG   95.0%
10.   Dacia   94.4%
11.   Citroen    94.1%
12.   Honda   93.9%
13.   Skoda   93.8%
14.   Subaru   93.7%
15.   Seat   93.6%
16.   BMW   93.4%
17.   Volvo   92.9%
18.   Renault   92.5%
=19.   Porsche   91.6%
=19.   Tesla   91.6%
21.   Audi   91.1%
22.   Volkswagen    90.2%
=23.   Mercedes   89.5%
=23.   Vauxhall   89.5%
25.   Nissan    89.3%
26.   Jaguar   88.7%
27.   Ford   87.8%
28.   Peugeot   87.4%
29.   Alfa Romeo   87.3%
30.   Fiat   86.4%
31.   Land Rover   81.4%
32.   Jeep   77.0%
That's from 2022, btw
Diesel till I die
Having said that, my last 5 cars have been Vauxhalls (Meriva, Astra H, Zafira B, Astra J, Astra K) and I've never had a major problem with any of them. Omega well before those five, which I did have problems with. Obviously never owned a Jag, so can't comment.
Diesel till I die
Rangie
Had 7 from that list over the last 10 years, and haven't broken down in any of them ,I just get them serviced properly & don't " tinker" with them myself.
Quote from: Rangie on 20 August 2023, 12:08:24
Same here, Mick. I don't want to risk breaking a fingernail  :)
Diesel till I die
Rangie
Quote from: STEMO on 20 August 2023, 12:31:44
Heaven forbid..😂
ronnyd
What's the auto box like in the Insignificant?
I've had my ML now for over 4 years & other than yearly servicing & tyres, I've not had to spend a penny on it ....  8)
wingman
I had my auto 2.0 CDti Insignia Elite saloon for 5 years with no problem apart from one faulty glowplug. Comfortable to drive, good economy, but not exciting.
Quote from: TheBoy on 19 August 2023, 16:59:19
The 6 speed manual is what finishes off most.  If you catch the bearing wear early enough, it's a £400 repair.  If you don't, it's a replacement box, which most places won't do, as all the 2nd hand boxes are semi shagged.
Plenty of info out there how to prove if wear is back on the gearbox - just search for 'M32 gearbox bearing' or similar
Insignia did not use the M32 (which was fully fixed as of around 2012), it had the F40 as the 2.0 CDTi had more then 320Nm of torque.
Migv6 le Frog Fan
Lexus / Toyota is to be expected really. They have long had a reputation for reliability. Bit Mini in joint third ? ! Do me a favour.  ;D
Quote from: Migv6 le Frog Fan on 21 August 2023, 10:16:57
I can't decide if those tables reflect the reliability of the cars or the expectations of those who typically purchase them!
Quote from: ronnyd on 20 August 2023, 18:36:31
Can't be any worse than the one in the Vectrum ;D
Quote from: Marks DTM Calib on 21 August 2023, 07:57:53
Well, if that transportr was anything to go by, the F40 aint much coop either ;D
The M32 fix with larger (IIRC) bearings isn't a permanent fix, it just prolongs the inevitable.  I looked at loads of ZAF-Bs with the newer designed gearbox ends, and all had shagged boxes.  That said, our resident used car seller did tell me I was being ambitious with a £4k budget for a 100k, 10yr old car ;D, so was probably looking at the tripe end of stuff.
Hence increasing our budget a bit, and actually getting something decent and more what she wanted....   ...but not stretch to her dream car of an Evoque ;D
Quote from: TheBoy on 21 August 2023, 11:13:50
There were no UK bound Zaf Bs ever built with the updated M32.
The fix (and it certainly does work) was a larger set of bearings, a new end plate to take them, improved bearing oiling and cooling.
I will send the apprentice around and she can try his Evoque, he has just had to order a new one and is a bit put out that he had to settle for the HSE as there were now Autobiographies available.  ;D
