Pages: 1 [2] 3  All   Go Down
Author Topic: Haltrac Hoist  (Read 11763 times)
Varche
  • middle of Andalucia
    • Golf Estate
Re: Haltrac Hoist
« Reply #15 on: 30 August 2023, 12:58:17 »
Omega roof rack and Halfords bike carriers going to the dump today. Only 22 years old….
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Haltrac Hoist
« Reply #16 on: 30 August 2023, 13:12:54 »
For some reason, none of my tools are older than 10yrs, 6 weeks......
There's an awful lot of space debris orbiting the planet at the moment. ;)
Re: Haltrac Hoist
« Reply #17 on: 30 August 2023, 20:44:17 »
He needed a new garage - well, the door, anyway. There was a piece missing from the old one. :-X
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Haltrac Hoist
« Reply #18 on: 30 August 2023, 23:03:05 »
Still got the wheelbrace that came with my brand new Ford Escort Mexico in August 1973 so now had it 50 years .
You must have owned all my previous cars...
Everytime I buy one, I have to replace the toolkit ::)
No spare wheel with the Mexican. Supposedly to save weight and the environment. ;D Definitely saves BMW a few quid supplying one. And gives them the possibility of charging you for something that should be standard.
FTFY :y
And toolkit is what the marketing wonks call a plastic bag with the world's cheapest shonkiest jacktm and a wheelbrace that an apprentice blacksmith would be ashamed of.
  • Online Online
Re: Haltrac Hoist
« Reply #19 on: 30 August 2023, 23:19:58 »
Mine actually includes the tool to release the electric parking brake  :o
Granted, it should have a mechanical one and not need the release tool, but I digress ;D
  • Chatham, Kent
Re: Haltrac Hoist
« Reply #20 on: 31 August 2023, 10:31:36 »
Early X5s came with a tool to manually release the transmission from park. It was necessary because the gearbox was made from chocolate, although it looked like it had been ordered from a dodgy website and delivered in a brown paper wrapper. Germans aren't always efficient, as later cars still had the tool, but the mechanism had been deleted from the gearbox.
Mercedes managed a different sort of oppswittery when they went to electric selectors on the steering column with (I think) the E-class which would only shift out of park with the engine turning. So a non-start for whatever reason meant an immobile car. Much communication with MB's technical department led to their bemusement that we thought that a lack of a manual release was poor engineering. The 2nd generation of A-class allowed you to put the trans in neutral, but only for a few seconds before shifting back into park. That's annoying, until your moronic colleague left the winch remote on the back of the truck last night.
Land Rover's first electric handbrakes were notorious for stripping the plastic gears in the gearbox between the motor and the cables - a design Renault admired so much they further under-developed it for the Megane, but that's a different rant. It's a one-way failure, in that the motor is still able to tension the cables but not release them. Which means by the time it's been operated a few times, the cables are bow-string tight, but the manual release looks like something Colin Chapman would have considered too flimsy. And I never did find out why the Discovery buries it inside the centre console(it's right at the bottom, which is a looong way down) but the RR Sport has it under the backseat.
VW decided to put their handbrake motors inside the caliper. Anyone who has ever taken a wheel off a car will appreciate why this a laughably bad idea. And because it's internal there's no possibility of releasing it without dismantling the caliper. On the car. With it locked on. At least most of them were FWD, so slipping an old wheel trim under each back wheel meant you could move the car under its own power. If it was an Audi you made damn sure that you rescued your wheel trims after doing a stealth deliverytm, as their service attitude is taken directly from the Ryanair employee manual.
Anyone who tells you that electric handbrakes are simpler than manual ones is too stupid to find their way out of a £20 gazebo with no sides.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Haltrac Hoist
« Reply #21 on: 31 August 2023, 10:53:48 »
Its called progress.  :y ;D
  • Chatham, Kent
Re: Haltrac Hoist
« Reply #22 on: 31 August 2023, 11:45:18 »
There are several definitions of progress.
The mendacious use is to imply that you mean the process of gradually improving something. This isn't applicable to any of my examples, as they didn't improve anything.
It can also mean moving forward in space or time. This is applicable, but is irrelevant.
Re: Haltrac Hoist
« Reply #23 on: 31 August 2023, 12:15:32 »
electric hand/parking/emergency brakes ..... the answer to a problem that never existed.
At least my ML's only goes on when I tell it to & not automatically when the car stops.
Varche
    • Golf Estate
Re: Haltrac Hoist
« Reply #24 on: 31 August 2023, 12:58:00 »
Agree. Plus the stupid interlock . Open your door and the handbrake comes on.
Migv6 le Frog Fan
Re: Haltrac Hoist
« Reply #25 on: 31 August 2023, 13:10:35 »
My comment was an ironic one.  ;)
  • Online Online
    • Grandland 1.5 diesel
Re: Haltrac Hoist
« Reply #26 on: 31 August 2023, 14:58:47 »
Wifeys car is only two years old and already I don't like the laboured sound of the electric handbrake when she switches off.
Diesel till I die
  • Online Online
Re: Haltrac Hoist
« Reply #27 on: 31 August 2023, 16:16:44 »
Same on the S :y
  • Online Online
Re: Haltrac Hoist
« Reply #28 on: 31 August 2023, 16:17:21 »
That's what you get for buying a VAG product >:D
Re: Haltrac Hoist
« Reply #29 on: 31 August 2023, 17:00:20 »
Not always .....  :-\ It'll go into Park if already in Drive, but doesn't always put the parking/hand brake on. In 4 plus years I've never quite worked out when or why it'll put the brake on. I know that if it puts on itself, it won't auto release & I have to release it - that's caught me out once or twice.
Pages: 1 [2] 3  All   Go Up
Page created in 0.333 seconds with 20 queries.
