Author Topic: Fixed it  (Read 1082 times)
Fixed it
« on: 13 September 2008, 19:33:39 »
Fault code 38 (lambda) now disappeared. Fault found and fixed - confirmed by a 100+ mile trip today, where no codes were logged and no EML coming on  :y
HolyCount
Re: Fixed it
« Reply #1 on: 13 September 2008, 19:36:41 »
Nice one  :y
Got a bit excited then -- thought it might have been Danny's lpg that was fixed
« Last Edit: 13 September 2008, 19:37:00 by HolyCount »
Dazzler
  • Haverhill, Suffolk
Re: Fixed it
« Reply #2 on: 13 September 2008, 19:38:02 »
What was it in the end then James?????
Sensor?? or another buggered wire ::)
Re: Fixed it
« Reply #3 on: 13 September 2008, 19:38:28 »
It wasn't the sensor - confirmed by swapping them, and not getting a fault on the passenger bank :y
Re: Fixed it
« Reply #4 on: 13 September 2008, 19:56:51 »
Congrats James.. :y
But what was the actual problem ?
Dazzler
Re: Fixed it
« Reply #5 on: 13 September 2008, 20:16:41 »
Congrats James.. :y
Its a secret.......
Re: Fixed it
« Reply #6 on: 13 September 2008, 20:19:10 »
Congrats James.. :y
Its a secret.......
Re: Fixed it
« Reply #7 on: 13 September 2008, 20:21:19 »
Congrats James.. :y
Its a secret.......
Have a guess - it was extremely simple in the end (thank god!)
Dazzler
Re: Fixed it
« Reply #8 on: 13 September 2008, 20:22:04 »
dodgey connection
Re: Fixed it
« Reply #9 on: 13 September 2008, 20:25:37 »
dodgey connection
In a nutshell yep! A little test between the wires on the sensor, and the wires just the other side of the connector on the loom, gave me an immediate result.
The black cable (from the sensor) was basically not buzzing through the other side to the loom - so a fault within the connector itself.
Just cut the wires for this one, and joined and all has been fine since. I'll have to get the soldering gun and heatshrink out as soon as it's dry!
Dazzler
Re: Fixed it
« Reply #10 on: 13 September 2008, 20:34:20 »
dodgey connection
Well found tho James, it can be a right pain sometimes to find these wiring faults >:(
So hats off to you matey :y
Re: Fixed it
« Reply #11 on: 13 September 2008, 20:36:31 »
dodgey connection
A little bit of the old me came out on this one.
Got fed up of thinking about it, so I went under there and laid in the piddling rain and dark, with a torch between my teeth and tested the wiring....
Was worth a soaking for the result, though ;D
Re: Fixed it
« Reply #12 on: 13 September 2008, 20:37:39 »
dodgey connection
 :y :y
iainb
  • West Midlands
Re: Fixed it
« Reply #13 on: 13 September 2008, 21:02:12 »
Well done  :)
 I can think of a few main dealers that cant sort these type of problems
