Heavy Oil Stain
Started by JamesV6CDX, 15 September 2023, 07:02:47
There must be some caravan dwellers with some tarmac 'left over' from a big job they were doing up the road James?  ???   ::)
That will last for ages.... Honest!  ;D
Quote from: Doctor Gollum on 16 September 2023, 06:41:56
Sounds like you have a 'make good' lease :-\
No, I just don't want the place looking like steptoes yard!
It's just an area I have almost zero knowledge of, so thought I'd gather some opinions :y
Quote from: johnnydog on 16 September 2023, 09:24:35
Cost will depend entirely on depth, area and type (density/composition/reinforcement). That said, if you're only talking a couple of square feet, it should be pretty diyable :y
F*ck me, you're a builder now as well....? :y
Do you have a better suggestion then ???
You will never get a patch to perfectly match the rest of the drive. Even cutting a section out and relaying will look slightly (or even vastly) different due to the different mix.
Diesel till I die
Quote from: STEMO on 16 September 2023, 12:33:20
Once done could the whole surface be sealed? Might that help visually?
Obviously how you deal with it depends on inside or out as you need a rougher surface outside otherwise it will be lethal in the rain/snow/ice.
dave the builder
Detergent (washing up liquid ) neat on the stain, scrub with a good stiff brush , then pour boiling water over ,scrub again , repeat several times
fullers earth* cat litter absorbs well ,ground into a fine powder(like cement)  if chunky, an excellent emergency "spill kit"  ;)
NOTE *
fullers earth cat litter is not a brand name , cheap, heavy "smart price" ,"no frills" cat litter is often fullers earth or contains it
" always read the label"  ;D
cat litter will obviously need cleaning up after ,dust pan n brush, hoover (other brands of vacuum suction device available  :P) then rinse the whole area with a pressure washer ,
replacing concrete is VERY expensive ,
concrete and block paving sealers are "OK" before spills , but can make it slippy ,and "hold" puddles ,
best to NOT spill oil in the first place ,but we are all human ,make mistakes
hands up , i've done it loads of times ,and the above info is based on experience of cleaning up my mess and other's mess :)
