Author Topic: Replace cats  (Read 6880 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Replace cats
« on: 26 September 2023, 08:02:30 »
On my 2002 3.2L Sport my cats are rattling and I have bought a new set.
I know it can be problematic to unscrew the nuts on manifolds and I wonder if there is a good method to do this without breaking the bolts holding the cats to the manifold.
Should I heat the nuts? Or can it be done without heating and still not breaking the bolts.
Appreciate any advice.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
Re: Replace cats
« Reply #1 on: 26 September 2023, 09:44:56 »
Manifold to downpipe ones?  Never had an issue on any of mine.  Ideally use a good hex socket rather than the usual 12 point ones.
If its manifold to head, never down that, DTM did all mine ;D
Jan Suhr
  • Nyköping, Sweden
Re: Replace cats
« Reply #2 on: 26 September 2023, 09:59:18 »
Thanks, it's manifold to down pipes.
Good to hear, I've had some anxiety about those bolts stuck and breaking the studs.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: Replace cats
« Reply #3 on: 26 September 2023, 11:11:51 »
Always give a good spray with releasing fluid long before you start 👍
Laying a rubber road.
    • Grandland 1.5 diesel
Re: Replace cats
« Reply #4 on: 26 September 2023, 11:38:21 »
And a good whack to the centre of each bolt head with a punch, screwdriver, etc, to allow the penetrating oil to get in there.
Diesel till I die
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Replace cats
« Reply #5 on: 26 September 2023, 11:53:48 »
It's more comfortable to ensure you're wearing your favourite yarmulke, facing Mecca on your mat while praying to the Holy Trinity that the stud doesn't snap.
If you want to do something that's actually useful, wire brush the grot off the nut and exposed threads before putting a socket anywhere near them. A little lube on those threads might help the nut turn over them, but any oil will do that.
Re: Replace cats
« Reply #6 on: 26 September 2023, 12:04:08 »
I disagree, it's helped me in the past, and it certainly can't do any harm.  But if you want to face Mecca on your prayer mat, don't be surprised if you end up on arsebook.
Diesel till I die
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Replace cats
« Reply #7 on: 28 September 2023, 16:46:16 »
Heat. Get them glowing red hot, then undo. Works every time
Hoof'land storeman.
