Author Topic: Passat Diesel - Cut out  (Read 11968 times)
« on: 07 October 2023, 21:33:11 »
I have a 2009 Passat Estate, purchased as a daily hack now the Rangie has gone to heaven. It's a 2.0 TDi, 6 speed manual. Very high miles - 209k. I bought it with 206k on the clock, and have done nothing other than a cambelt kit and water pump (DIY) about 2000 miles ago. It has always started and always driven exceptionally well.
Day before yesterday I left home, drove less than a mile, and it just suddenly lost power and died. Like fuel starvation. I managed to roll into a layby, tried to restart, no go. It was trying (and tried harder when cranking at WOT) but wouldn't go. I didn't try for long, because I needed to get somewhere, so I walked home to get the other car.
Today I went back to the VW. Plugged in a code reader - no codes. Cranked it a bit, and after a short while it caught, coughed a bit, and then ran fine.  I went for a spin, covered 10 miles without any issue at all, plenty of power.
The fuel tank was full, almost to the brim, when it broke down. It was filled up the night before and had only covered 15 miles home. BUT, when I last refuelled the night before, it was literally on fumes. Range saying 0, gauge not moving (I know, I know!)
I am wondering if I ran it so low, that it took in some air or crap or similar, but odd that it took 15 miles after refueling to show up?
Guess all I can do is keep an eye and see if it reoccurs  :-\
Re: Passat Diesel - Cut out
« Reply #1 on: 08 October 2023, 04:59:48 »
Does it have a lift pump?
Also, might be worth changing the fuel filter, although it's a finickety process to bleed.
« Reply #2 on: 08 October 2023, 10:15:08 »
I believe it does.
I changed the filter when I did the cambelt kit 2000 or so miles ago - I filled the housing with diesel, and it fired straight up with hardly a cough! :y
« Reply #3 on: 08 October 2023, 10:16:17 »
Started on the button this morning, I'll take her for a (local!) drive today and see what happens. I think it's going to be a case of just see if there's a repeat, and hope it was due to the previous low fuel!
« Reply #4 on: 08 October 2023, 10:31:59 »
I ran the R Class out once and it wasn't happy for a while after... fortunately it didn't kill the lift pump :-[
If it fired straight off then it sounds like you've gotten away with it.
    • Grandland 1.5 diesel
« Reply #5 on: 08 October 2023, 11:42:45 »
If it fired straight off then it sounds like you got away with it.
Fixed for Englishness
Diesel till I die
« Reply #6 on: 08 October 2023, 18:14:37 »
Gotten is the past participle of getting. :P
« Reply #7 on: 08 October 2023, 19:01:39 »
 :-X
« Reply #8 on: 08 October 2023, 19:02:56 »
Gotten is what Yanks do ....
« Reply #9 on: 08 October 2023, 20:15:29 »
I know that, because I speak English, not an American bastardisation of it.
Sorry, Al, you just can't be a Yank, no matter how hard you wish  ::)
« Last Edit: 08 October 2023, 20:18:01 by STEMO »
Diesel till I die
« Reply #10 on: 08 October 2023, 22:40:16 »
Ok, how about James is getting away with having run his fuel tank dry... ;D
« Reply #11 on: 08 October 2023, 22:53:53 »
Where does he say he ran his fuel tank dry?
Diesel till I die
« Reply #12 on: 08 October 2023, 22:57:20 »
Second last paragraph in his original post.
« Reply #13 on: 08 October 2023, 23:07:45 »
it was running on fumes .... but didn't run dry  :-\
« Reply #14 on: 08 October 2023, 23:47:45 »
Splitting hairs ;D
