Author Topic: Passat Diesel - Cut out  (Read 11862 times)
    • Grandland 1.5 diesel
Re: Passat Diesel - Cut out
« Reply #15 on: 09 October 2023, 06:49:59 »
"it was literally on fumes. Range saying 0, gauge not moving (I know, I know!)
I am wondering if I ran it so low"
I don't even see the word 'dry'  :-\
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #16 on: 09 October 2023, 08:53:47 »
Ok, how about James is getting away with having run his fuel tank dry... ;D
I ran the R Class out once and it wasn't happy for a while after...
I take it you "got away with"  it      :-\  :D
"MOIST" then  :-\   ;D
I'm off to read OOF terms and conditions ,
seems the "grammar  police" and "English spelling division" are  scrutinising OOF  :o
I'm constantly making grammatical and spelling errors  when posting  :-[
I need to check how many points I've totted up ,I might well loose my "OOF posting licence"    :P
all joking aside ,,,
I hope James hasn't had further issues  :)
« Reply #17 on: 09 October 2023, 09:02:45 »
That's fine ... forums are not English tests/exams.  :y
It's just the Americanisms that pi55 me off ....   :-X Other than the phrase 'ill gotten gains' ..... wtf uses 'gotten' on this off the Atlantic?  :-\
« Reply #18 on: 09 October 2023, 10:59:45 »
It's just the Americanisms that pi55 me off ....   :-X Other than the phrase 'ill gotten gains' ..... wtf uses 'gotten' on this side of the Atlantic?  :-\
Corrected for exclusion and grammar  ;D
Diesel till I die
« Reply #19 on: 09 October 2023, 11:32:24 »
Car was fine yesterday. It's got a bit of a squeak only at idle / very low revs. Hoping it's the aux belt bedding in, and not the HP pump!
I'll take the flack for running the tank "moist"  ;) Let's face it, it wouldn't be a first and probably not the last time I've done it. It's usually the Omega estates which catch me out though - normally more careful with a diesel for obvious reasons....
« Reply #20 on: 09 October 2023, 12:04:37 »
Where is this place of which you speak? :P
« Reply #21 on: 09 October 2023, 14:04:31 »
far far away .....  ;)
« Reply #22 on: 09 October 2023, 16:22:32 »
Might be air, the VW common rails are a bit shitty for this as they do not self prime and if actually ran out need a bit of work to get them running (usually cranking and popping the return pipe off the filter). The filter housings are easy to crack when changing the filters also.
That said, it could also be a crank sensor showing no output, you will just have to run it and see what happens
« Reply #23 on: 10 October 2023, 23:40:27 »
cheers Mark :y - 100 miles or more now and not missed a beat... I'm keeping everything crossed it was just air from when I ran it so low....
