If you Bought a New Car? What Would You Choose?
Started by Mr Skrunts, 15 October 2023, 15:45:52
Still strikes me as a solution to a problem that doesn't exist.
Quote from: Marks DTM Calib on 18 October 2023, 08:04:05
Quote from: Doctor Gollum on 17 October 2023, 15:00:47
A plug in hybrid is a total waste of piss and nowt more than a subversive way to get everyone to fit charging ports at home.
A conventional hybrid is practically a much better solution if only because it doesn't require an external power source in order to work.
A plug in hybrid is a conventional hybrid with the ability to charge from the mains and generally a larger battery, so actually far more useful
It would be even more useful if it had the ability to charge from either mains or engine.
Diesel till I die
Quote from: Sir Tigger KC on 17 October 2023, 18:23:45
Quote from: http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/thumbsup.gifSTEMO on 17 October 2023, 18:11:49
Quote from: Sir Tigger KC on 17 October 2023, 17:19:10
I still have a Range Rover L322 itch, and I'd better scratch that itch soon before they get too old and knackered!  ::)
And you, too ;D
;D  Yes.
That's one of my justifications. Medicinal purposes.  ::) A RR will be easier to get in and out of with my knackered hips, and when I eventually get round to getting them done it will be easier on them while they're still bedding in.  :y
Getting in and out of a car is quite difficult with knackered hips.  :-\  :(
This forum is like a chat in God's waiting room. Full of old people ready to drop off the perch. >:D ;)
Quote from: Field Marshal Dr. Opti on 18 October 2023, 11:58:30
And you, too ;D
;D  Yes.
We're so glad to have you leading the charge to the Pearly Gates M'Lud!  :)        ;D
Quote from: Sir Tigger KC on 18 October 2023, 12:12:58
And you, too ;D
;D  Yes.
You go first Tig, and in 50 or 60 years I'll come along. :)
Quote from: Field Marshal Dr. Opti on 18 October 2023, 13:09:59
And you, too ;D
;D  Yes.
Oh your appointment with the Grim Reaper will be long before mine so you'll be dust when my time comes.  ::)
Maybe the wind will blow your dust through the Pearly Gates after me.  :)
Unless the lift takes you downwards of course!  :o  ;D
Quote from: Sir Tigger KC on 18 October 2023, 14:17:52
And you, too ;D
;D  Yes.
I do hope so. The only thing to do in heaven is to read the bible and look pious. :-\
Below stairs the devil throws a great party, with plenty of raunchy devil girls, booze, and fine food. >:D >:D
Rangie
None of us can change our position in the queue, and then you wake up dead..😂 I wonder if you know when you are dead ?
dave the builder
Quote from: Rangie on 18 October 2023, 15:20:08
I imagine other people will know ,doesn't take the flies long  >:D
I imagine, because obviously I can't know for certain, that being dead is much like before we are born, with no sense of anything whatsoever.
It's rather scary. :-\
Happened to me a few times in 2009 when I was rushed into hospital.
There one second and gone the next, was just like tuning the light off.
Dont know how I was revived but it was a weird and vague experiance coming round with all the people arround in a wierd sort of panick, I was just very confused and then realeaved after realing I was alive.
Still here to complain and cause havock :y
Quote from: Mr Skrunts on 18 October 2023, 21:53:10
You died in 2009? That explains a lot  ;D
Diesel till I die
Quote from: STEMO on 18 October 2023, 22:13:04
Go back to 1971 after an accident and in a coma for 2 weeks imagine wakeing up to find surgeons had opened up my head trying to find my brain and leaving me with a 12"scar across the side of my head from front to back.  That left a lot more to think about.  ::) :-X
Quote from: STEMO on 18 October 2023, 11:27:11
It charges under braking, charging from the engine is less economical than using the engine to drive the wheels :y
And its surprising just how much charge you get from braking alone, as an example, on my commute I can see 9kWh of regenerated energy gained and that's a lot of motorway driving where its constant speed.
Had a read about the new qashqai e-Power this morning, seems a bit of a con. Engine constantly charging a battery which powers a motor which drives the front wheels. The manufacturer blurb says 55mpg and 1000km from a 55 litre tank of petrol. The reviewer in this report got only 35mpg, admittedly with snow and ice on the roads. But my 1.6 diesel will get 1000km from a 55 litre tank so, at well over £30,000, you'd have to very concerned about what does/doesn't come out of the tail pipe :
https://www.wintonsworld.com/nissan-qashqai-e-power-190-tekna-hybrid-review/
Diesel till I die
