Author Topic: No gear selector lights  (Read 5953 times)
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
« on: 11 November 2023, 15:32:53 »
Afternoon All
My 2002 2.6 had no gear selector lights with engine management light and TC lights up when i took it off the drive earlier. Reverses okay but limp mode on forward gears.
Had the AA out with their whizzy code reader and got fault code 0705 told its drive position sensor, does this sound right?
If so
What part number are they and are they hard to fit?
Thanks
Re: No gear selector lights
« Reply #1 on: 11 November 2023, 18:16:04 »
Start with cleaning the selector switch. There's a guide  ;)
artsoul_no1
  • sidcup, kent
« Reply #3 on: 12 November 2023, 11:28:58 »
Thanks all
So more likely to be the selector switch than a sensor? I discounted the switch as I thought all the gear selector lights came on rather than no lights.
Is it as easy as undoing two bolts, unclipping connectors and taking off?
« Reply #4 on: 12 November 2023, 11:57:09 »
Do you get any lights at all when moving the stick, even if s brief flash.
If not, might be worth running through the fuses first.
artsoul_no1
  • sidcup, kent
« Reply #5 on: 14 November 2023, 14:01:01 »
It was the fuse!!!!
Went straight to the worst-case scenario first, doh!!
Thanks again for everyone's help
« Reply #6 on: 14 November 2023, 14:08:27 »
My kind of fix!
Excellent news :)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #7 on: 16 November 2023, 17:18:28 »
It was the fuse!!!!
I'd be asking the AA for a refund!
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #8 on: 16 November 2023, 18:30:30 »
When I bought my Boxster very cheap, the ABS light was on and the speedo didnt work.
Owner suspected serious and expensive electrical problems. It turned out to be a blown fuse.  :D
