Fickin modern cars
Started by STEMO, 29 November 2023, 21:05:19
Quote from: TheBoy on 30 November 2023, 13:04:20
Assuming its not its way of saying it needs more pigs piss....
What is the quality of the pigs piss you have been using?  Has it been stored properly (out of sunlight, and at room temperature)?  This alone is why you shouldn't buy it from the petrol station where its left out in the sun, and then left to freeze.  You can get cheap gadgets to measure its quality.
Beyond that, the injectors seem to clog up and need cleaning up, as they get stuff with the white cystalised stuff around the injector into the SEC.
All this shite to appease the misinformed, stupid, waste of carbon do-gooders.
Strewth....this is gloomy  enough to drive the old lad to buy a car that runs on petrol. ::)
Quote from: STEMO on 30 November 2023, 11:54:02
Quote from: Andy B on 30 November 2023, 11:49:31
it seems that Adblue faults are also a problem with Mercs too .....
(he says with fingers crossed  :-X )
Adblue faults on all makes in the cold weather, Andy, it's a crap system thought up by fickin idiots.
Ooooo......I sounded like Jaime there for a moment  ;D
;D ;D
Rangie
That's why the Range Rover will be last diesel vehicle I own, can't be doing with all this ad blu nonsense.
Quote from: TheBoy on 30 November 2023, 13:04:20....
Beyond that, the injectors seem to clog up and need cleaning up, as they get stuff with the white cystalised stuff around the injector into the SEC. .....
I thought it crystallised in the tank  :-\ I know that Forte do an additive to prevent it doing so.
https://www.forteuk.co.uk/product/exhaust-crystal-preventer/
Quote from: STEMO on 30 November 2023, 13:06:33....
So I guess the pig piss has been sitting in the tank for quite a while
Pretty sure I've seen that MB suggest Adblue is drained from the tank & replaced every year  :-\
Quote from: Andy B on 30 November 2023, 13:25:32
I actually added a bottle of that just after we got the car. But I'm not going to mention that because in the warranty T&C's it mentions that they won't be responsible for any damage caused by adding stuff to the engine oil, fuel, etc.
Diesel till I die
It can, but most of us use our cars far too much for that to occur.  But look online to see how the DEF injector clogs with the shite.  Fortunately easy to clean in most cases, but means removing undertray to drop that bit out the exhaust.
YZ250
Adblue fault can be a clogged piss injector as mentioned but can also be the Adblue tank pump or the inline heater, which when both replaced can be bloody expensive on some models. Expensive as in well over a grand if paying for fitment as well. The exhaust injector can be washed out but it's still an unnecessary faff.
Of course, the Adblue feature can be mapped out, tut tut.  ::)
The difference between a fault and a top up warning is that the countdown mileage says no re-start in around 600 miles and drops rapidly on each use of the vehicle, whereas a top up message usually starts at around 1500 miles left before no re-start and comes down normally.
Quote from: STEMO on 30 November 2023, 11:44:16
Stealers must be busy, three weeks tomorrow was the first appointment. Car is saying 'Starting impossible in 700 miles' now.
If still under warranty leave it with the dealer but insist on a courtesy car for the entire duration. When I left my 2015 XFR with Watford Jaguar for a week they loaned me an almost new 300 BHP 3.0D XF complete with a full tank of derv. :)
ronnyd
Quote from: STEMO on 30 November 2023, 15:28:09
I actually added a bottle of that juser t aftwe got the car. But I'm not going to mention that because in the warranty T&C's it mentions that they won't be responsible for any damage caused by adding stuff to the engine oil, fuel, etc.
Hope they don't read OOF then.  ;)
Quote from: YZ250 on 30 November 2023, 16:51:14
Hers doesn't give a countdown, it just says it's low.  So kinda forces you to pull yer finger out as soon as it pops up.  Which reminds me, it popped up a few days ago, but far too cold to piss around with ;D
Quote from: TheBoy on 30 November 2023, 16:02:37.....
Unfortunately that's not the case with my ML, though when it is used, it get's driven fairly hard & is frequently towing.
(fingers crossed) not had any problems with it in 4 1/2 yrs & 40-ish thousand miles. It gets a gallon of Adblue as & when I remember ..... it's yet to actually ask for any. No gauge fitted to mine .... I believe there is on later MBs
Hers is still under warranty, so shouldn't need to take such drastic action just yet.
But.....https://www.yorkshiredpfcentre.com/ad-blue  :-X
Diesel till I die
dave the builder
you've still not said if you've topped up the pig p155  :-\ that i noticed
Viral_Jim
Quote from: TheBoy on 30 November 2023, 17:20:29
In this weather that sounds more like a her problem than a you problem. Much like the 4x low tyre pressure warnings on her Evoque this morning.... ::) ;D
