Caustic Soda
Started by Mr Skrunts, 06 December 2023, 10:54:16
There was a thread not so long ago regards removing oil from a drive. (I searched but could not find it)
So today I came accros some Caustic Soda in a container looking a bit worse for wear.  I was going to dump it but decided to look up its uses.  (we used to use it a lot at work (Food Factory) with boiling water to clean the concrete floors.
So Googled it.
CLEANING & SANITIZING (dustbins, kennels, stables, driveways etc) Add 1-2 tablespoons of Caustic Soda per 5 litres of water. Scrub soiled area with solution, then wash down thoroughly with water. Removes oil and soot. PAINT STRIPPING Add 250g Caustic Soda to 1 litre of cold water.
https://www.google.com/search?q=caustic+soda+how+to+use&client=firefox-b-d&sca_esv=588338046&sxsrf=AM9HkKnFMvwucztPBR4eEdbcNUPM3vHlOg%3A1701859241237&ei=qU9wZfP5DaiqhbIPhd-0wAU&ved=0ahUKEwiz8p_cz_qCAxUoVUEAHYUvDVgQ4dUDCBE&uact=5&oq=caustic+soda+how+to+use&gs_lp=Egxnd3Mtd2l6LXNlcnAiF2NhdXN0aWMgc29kYSBob3cgdG8gdXNlMgsQABiABBiKBRiRAjIGEAAYFhgeMgYQABgWGB4yBhAAGBYYHjIGEAAYFhgeMgYQABgWGB4yBhAAGBYYHjIGEAAYFhgeMgYQABgWGB4yBhAAGBYYHkiUWlCxDljlVHABeAGQAQCYAVegAfkFqgECMTC4AQPIAQD4AQHCAgoQABhHGNYEGLADwgINEAAYgAQYigUYQxiwA8ICBRAAGIAEwgIIEAAYFhgeGAriAwQYACBBiAYBkAYK&sclient=gws-wiz-serp
Sorry if it was mentioned in the OP but the bit about the paint stipping was also  interesting.
our cleaners use caustic too for cleaning through pipework & sauce filler bowls etc ..... all contained system (apart from where it leaks!  ::))
Quote from: Andy B on 06 December 2023, 10:58:53
Be trouble if that made it into the beanz
Diesel till I die
YZ250
I used to use caustic soda to clean the exhaust baffles on my Two Stroke Moto X bike. Obviously I'd remove the baffles from the exhaust first.  :y
Just don't use it to dip Aluminium in, unless you want to dissolve the Aluminium.  ::)  ;D
Quote from: YZ250 on 06 December 2023, 11:25:45
Ditto. The exhaust would get quite hot. I'd also stick the end of the 'zorst' into a big spud to stop the contents coming out. :)
Seemed a good idea at the time. :)
Migv6 le Frog Fan
Does anyone remember Harpic toilet cleaner ?
It contains caustic soda. When I was about 6 years old I chugged down a whole bottle of the stuff, apparently because I thought it was similar to that sherbet stuff.
Anyway, up the hospital, tube down into stomach to pump it out. I didnt like that idea much so sunk my teeth into the tube.
Nurse slapped me hard round the chops, and when I opened my mouth to cry she shoved something in to stop me closing it again.  ;D
About 6 months later, I took a liking to Windolene and downed a bottle of that. so, up to the hospital etc. etc........... ;D
Quote from: YZ250 on 06 December 2023, 11:25:45....
When I worked at Hall's sweets I was after a big tub to soak something or other in caustic, we had a load of plastic tubs but I could only find an ally tub so used that.  ::) I filled the workshop with acrid fumes!  :-[
YZ250
Quote from: Andy B on 06 December 2023, 13:47:37
;D
One of the chaps I did my apprenticeship with came up to me one day and told me he'd put his exhaust in the caustic tank to clean it. I said "I thought you had ally tips on your pipes. He said "Oh shit" and ran to the caustic room. It was too late, the strong concentration caustic had eaten his exhaust tips.  ;D
The MOD place where I worked had a anodising tank which was great for making ally motorcycle parts look bling. I had coloured anodised foot pegs and levers years before trick bits came out.   ;D  :y
Quote from: Migv6 le Frog Fan on 06 December 2023, 13:30:32
I used to get called Harpic. Folk reckoned I was clean round the bend.
Diesel till I die
So you swallowed poison not once....but twice. ::) ::) ::) ::) :)
Migv6 le Frog Fan
At least twice, yes. Also countless accidents that needed a quick trip to A&E. My old Mum reckoned they would soon name it after me as a tribute for the most regular customer.  ;D
Used to count up the stitches I had over the years, but lost count somewhere when it got well past 100.  ;D
countrywoman
The old boys at work said caustic soda brings up the bones nice and white
