Pages: [1] 2 3  All   Go Down
Author Topic: Speedo and rev counter not working  (Read 32556 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 24 December 2023, 14:19:18 »
Good afternoon guys, hope you’re all well.
Haven’t driven the omega for a while and I’m using it over the Christmas period. Drives beautiful as always. But no speedo and no rev counter. Temp and fuel gauges still working. And the rev needle is flickering really fast.
I’m hoping it’s not the start of ABS ECU needing doing but if it is I’ll have to make time for it. Any ideas?
Oh and no ABS or TC lights on, just the issue with the dials 🥰🥰🥰
RIP Paul Lovejoy
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Speedo and rev counter not working
« Reply #1 on: 24 December 2023, 14:53:22 »
This seems quite a common fault  :(
more so on 2.6 & 3.2
swapping the binnacle solves it ,so there's obviously something wrong with the clusters
you need to swap the binnacle from the same engine size  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #2 on: 24 December 2023, 15:00:25 »
Something like THIS clicky  is a quick solution if you need an MOT (working speedo is required)
« Reply #3 on: 24 December 2023, 15:13:48 »
Have you recently jump started it, or used a shitty old battery charger?  Some of the faulty ones I'm aware of might have been due to to these...
Webby the Bear
  • Northampton
« Reply #4 on: 24 December 2023, 15:26:46 »
Thanks boys. So we think it’s the cluster? If so I’ll whip it off and send it to ECU testing or BBA. Thanks all and merry Christmas.
Ps TB no jumping/charging recently 🥰🥰🥰
RIP Paul Lovejoy
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #5 on: 24 December 2023, 15:39:10 »
Mine's a 2.5 like yours Webby, and it did exactly the same a few years ago, flickering needle and no rev counter speedo.
In the end I removed the binacle, cleaned the contacts and refitted, but it didn't make much difference.
However I got better results after removing and checking / cleaning the 2 big round multi-plug connectors by the fuse box. It's been running fine for 3 years without a problem.
Omega 2.5 V6 Facelift Estate.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #6 on: 24 December 2023, 15:43:45 »
Several OOFers have swapped the cluster to resolve it .
mileometer still works ,just the tach and speedo needles die
it can start working again .then die again  :(
« Reply #7 on: 25 December 2023, 08:34:15 »
Always worth reseating the cluster on its connector, but ultimately it does seem to be the cluster itself that fails, particularly on FL models.
At one point I wondered if it was it was losing its coding due to age, but I'm sure I reapplied that on some of Gixer's several failed clusters.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #8 on: 25 December 2023, 12:29:25 »
Hello, interesting, what is this "Reseating Cluster", how to do this?
    • Grandland 1.5 diesel
« Reply #9 on: 25 December 2023, 13:31:01 »
Give it a whack  ;D
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #10 on: 25 December 2023, 14:39:28 »
Give it a whack  ;D
;D
indeed  :y
BUT...
You have to use the official GENUINE VAUXHALL RESET TOOL "purchased from a dealer, that you walk into" or you invalidate the warranty  :-X
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #11 on: 25 December 2023, 14:49:01 »
Give it a whack  ;D
;D
indeed  :y
BUT...
Tools of the trade Dave?
« Reply #12 on: 25 December 2023, 14:50:52 »
Give it a whack  ;D
;D
indeed  :y
BUT...
The bumper installation tool of window trim installation tool both work really well.
Bitch mittens not required and there's possibly even a guide for it :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #13 on: 25 December 2023, 16:00:40 »
Give it a whack  ;D
;D
indeed  :y
BUT...
i've owned a lot of Vauxhalls , so having the right tools to work on them makes sense
countrywoman
  • worcestershire
    • skoda yeti
« Reply #14 on: 25 December 2023, 16:30:04 »
I have an 8lb sledge hammer ,that will fix it!!
Pages: [1] 2 3  All   Go Up
