Lotus omega v8 conversion
Started by bloodwheel, 26 December 2023, 20:07:01
bloodwheel
Quote from: Migv6 le Frog Fan on 28 December 2023, 16:33:39
I know that, but the OP question is about putting a V8 into an old Carlton shell. So no connection with the straight 6 Lotus version at all, just a mention in the title for some strange reason.
Unless Ive missed something and he is actually mad enough to put an american V8 into a genuine Lotus Carlton ?   :o
Not mad ,maybe a little crazy. :y
Actally bought me a lotus replica ,not the real deal.
But there is no engine or transmission in the car.
Im trying to find info if somebody had put a v8 in omega a ,but its hard to find info on the internet.
Would it fit?
Migv6 le Frog Fan
In that case I admire what your trying to do.  :y
Problem here is that this forum is mainly for UK Vauxhall Omega, which replaced the Carlton.
The Carlton to you is the Omega A. Little if any info on those cars here unfortunately.
LC0112G
Quote from: Migv6 le Frog Fan on 28 December 2023, 19:54:43
My main issue would be that its an insane thing to even consider. Ruining a very expensive car by dropping an old lump of yank iron in to replace the Lotus developed engine already in there.
That's assuming the current engine is servicable or reparable. We don't know that.
If it's put a rod through the block,(which I have seen - still got that block in the lockup) then getting a 'new' or recon C36GET will be a lot more expensive than throwing in a V8.
Lotus have already done some of the work required - Google Corvette ZR-1. Same/similar gearbox and same ECU. You won't get a ZR1 engine for £5K though.
LC0112G
Quote from: bloodwheel on 28 December 2023, 20:00:16
Would it fit?
If it's a replica, you will never get your money back whatever you do. Best bet would be to try and find a Carlton GSi3000i or a Senator 3000i with engine and gearbox in it. These are probably rarer now than "Genuine" Lotus Carltons/Omegas, but if you can find one in a scrappy or eBay then the  parts should just swap over. There is a 12 valve and a 24 valve version of the GSI3000. 24V is higher powered, but the 12V is preferred my many owners for strength and reliability. Ok 'only' 220BHP ish(for the 24V), but should be a shed load cheaper than a V8 conversion.
Would it fit?
It will almost dro straight in, as per my previous post.
https://www.ebay.co.uk/itm/393970001266?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=3jm2BtF2RsO&sssrc=4429486&ssuid=Ht8iHAwYSta&var=&widget_ver=artemis&media=COPY
Plus the book I linked to earlier and the full copy of the book F-Bodies Inc produced in 2007 F-body Inc. - Facebook https://m.facebook.com/groups/372900023515328/ may be f use.
I know Rob had the thick end of £20k into his Omega B and he did all the fabrication work so expect it to cost $$$
bloodwheel
Quote from: Migv6 le Frog Fan on 28 December 2023, 20:12:35
Aha, thats why i cant find info about omega/carlton on this forum.
In sweden this cars are all called omega...
I appreciate the info.
Thanks.
The car is based on a om..carlton 3000, but the engine and trans is gone.
Its cheaper to  find att chevy v8 in sweden then a original engine..
LC0112G
Quote from: Doctor Gollum on 28 December 2023, 23:12:37
It won't. Many have started down that route and I'm not aware of any that have succeeded in a RHD Carlton.
The Carlton/OmegaA has a different subframe and steering system to the Commodore. They look similar, but there are very few parts that are inter-changable between them.
LC0112G
Quote from: bloodwheel on 29 December 2023, 08:42:54
Thanks.
The main source for help on the older Omega A / Carlton, and especially the Lotus Carlton/Omega is a club called The Autobahnstormers. There is a considerable overlap between info here and there, and some of us are members of both. There is an internet forum, but access requires club membership - I think it's £30 a year.
If you need help on an Omega A /Carlton issue then that's were I recommend you go. However, I've been a member since about 1997 and I don't remember anyone successfully completeing a V8 transplant into a Carlton.
Quote from: LC0112G on 29 December 2023, 12:23:13
OP is in Sweden so not sure why that's an issue   ???
Fitting a subframe and rack from a suitable vintage Commodore should fix that particular conundrum for rhd.
Essentially this is what Rob ended up doing because the pitman arm movement is marginally affected by the right hand header. But yes, the engine will happily fit into the available space.
Sounds like an interesting project to me, and just because it might not have been done before, doesn't mean it can't be done.  :-X   :y
This might not be a Carlton/Omega A forum, but there is a lot of knowledge and experience here which you might find useful, and you'll learn to filter out the naysayers!  ;D
I for one would be interested to see how you get on if you decide to go ahead, and I'm sure many others here will be interested as well, so it would be great if you keep us updated!  :)
With photos of course!  ;)  :y
YZ250
There was a 1987 Vauxhall Carlton V8 built by Dave Cook Racing Services, near York. It was built for the Thundersaloon Racing but I don't think there was much original Carlton left by the time it was ready for the track. Apparently the rear differential was Holden, the engine was Chevrolet, mated to a ZF gearbox.
Keith ABS
 Biggest issue is the antiquated steering
You would need to change it over to a Corsa C column and rack
The header will clash on the steering box side
There is a bloke working for 456flb who has a Lexus V8 in his Carlton( Omega A)
He has the Corsa steering set up
Car handles like a hot hatch
