Pages: [1] 2 3  All   Go Down
Author Topic: One sided heating.  (Read 52021 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
One sided heating.
« on: 28 December 2023, 16:39:02 »
Noticed recently that the drivers side of my Omega only blows cold air, while the other side and rear still have nice hot air.
Something to do with those little vacuum valve things down under the dash area ?  :-\
Re: One sided heating.
« Reply #1 on: 28 December 2023, 18:41:13 »
Sort of, blend flap probably come off the servo.  Behind the forward edge of centre console if memory serves.  Hopefully somebody will confirm location :)
Migv6 le Frog Fan
« Reply #2 on: 28 December 2023, 19:51:39 »
Thanks. I will have a gander when the current (if not permanent) bout of cba passes.  :y :)
« Reply #3 on: 28 December 2023, 22:41:31 »
It's behind the very front piece of the centre console just forward and above the tab that locates it to the tunnel.
Migv6 le Frog Fan
« Reply #4 on: 28 December 2023, 23:45:21 »
Will try and go have a sit in the Mig tomorrow and hopefully work out what / where you mean.
Cant really picture it in my head at the moment. cheers.  :y
« Reply #5 on: 29 December 2023, 04:05:27 »
it's the side piece into the foot well.
« Reply #6 on: 29 December 2023, 10:46:59 »
Blimey, my memory sometimes works ;D
« Reply #7 on: 29 December 2023, 11:30:28 »
It happens  ;D
It stuck in my mind because first time I had the same issue, I got it reattached in a snowy layby...
Migv6 le Frog Fan
« Reply #8 on: 29 December 2023, 14:25:51 »
Am I looking for a rod type thing thats become detached from its hole, or a vac pipe thats fallen off ?
Had a quick look but cant see a lot in there. :-\
« Reply #9 on: 29 December 2023, 15:10:25 »
It's a plastic lever ;)
It's also black which really helps... Close your eyes, and get stuck in as though your looking for the man in the row boat ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #10 on: 29 December 2023, 15:51:10 »
;D ;D ;D
Migv6 le Frog Fan
« Reply #11 on: 29 December 2023, 16:33:43 »
I can see the plastic lever, which has a hole inthat looks like a rod has popped out of it. Is that right ?
If it is, I have no idea where the rod has gone.
« Reply #12 on: 29 December 2023, 21:56:06 »
Just move the lever to the position in its range of movement that is opposite its current position and worry about reattaching it in the spring. :D
Migv6 le Frog Fan
« Reply #13 on: 29 December 2023, 23:12:21 »
Ah, so Im looking for a spring.  :)
Thanks.  :y
« Reply #14 on: 30 December 2023, 00:17:35 »
Thanks.  :y
After winter not a sprung device  :D
Pages: [1] 2 3  All   Go Up
Page created in 0.022 seconds with 20 queries.
