Author Topic: Signum ATF.  (Read 50648 times)
Signum ATF.
« on: 05 March 2024, 18:49:58 »
Can members who know more than me post a link for the correct ATF  (and amount required) for a 2007 2.8T.
The job itself does not look that difficult.
Mrs Opti says drop it at WBAC and run. :)
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: Signum ATF.
« Reply #1 on: 05 March 2024, 19:03:01 »
Reg number in here...  :y
https://whatoildoineed.com/
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Signum ATF.
« Reply #2 on: 05 March 2024, 19:06:29 »
Strikes me Mrs. Opti is talking sense :P :P
Re: Signum ATF.
« Reply #3 on: 05 March 2024, 19:28:09 »
They are offering £1160.....before I arrive.
£xxxx......after they see the car and start finding faults with it. :-X
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Signum ATF.
« Reply #4 on: 05 March 2024, 20:25:16 »
It'll be in the Manual.
Hoof'land storeman.
Re: Signum ATF.
« Reply #5 on: 05 March 2024, 20:42:31 »
Don't think I ever had one.
biggriffin
Re: Signum ATF.
« Reply #6 on: 05 March 2024, 21:27:28 »
I'm guessing it's fitted with the Asian Warner, gearbox these use a mineral oil, it takes about 7L but you have to drain and fill a few times. It's possible AW-1 or ATF3309
Hoof'land storeman.
Re: Signum ATF.
« Reply #7 on: 06 March 2024, 12:02:16 »
Drain and fill a few times?......sounds expensive and time consuming.
Why so, BG?
Can't I simply drain out 7 litres of the old crap and refill with 7 litres of the new stuff.
Re: Signum ATF.
« Reply #8 on: 06 March 2024, 12:15:53 »
You wont get it all out, so you end up mixing significant amounts of old shitty fluid with new, hence having to do a few times as each draining reduces the ratio of the old fluid.
Re: Signum ATF.
« Reply #9 on: 06 March 2024, 12:27:12 »
Ah....I see. Thanks, TB.
So how much oil is needed to get 7 litres of clean ATF?......or is this not really possible?
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Signum ATF.
« Reply #10 on: 06 March 2024, 12:50:23 »
the issue is the torque converter . if you drain the sump you drain a percentage of the fluid but none of the torque converter and it holds a lot of fluid . so as the engine is run again the new fluid circulates and replaces the fluid in the torque converter which mixes with the old fluid . every time you drain and refill you get more of the old "mixed in" fluid out !
Re: Signum ATF.
« Reply #11 on: 06 March 2024, 14:30:11 »
You learn something new every day.
I thought it would simply be a case of drain the old and refill with new.
    • Grandland 1.5 diesel
Re: Signum ATF.
« Reply #12 on: 06 March 2024, 14:54:46 »
IIRC, over half of the ATF is retained in the torque converter. So you will only drain c.3.5 litres of oil first go.
So....in my understanding....first oil change gives a 50% ratio of old to new, second one gives you 75%, third one gives 87.5% and so on. So 10.5 litres of ATF will, more or less, give you an acceptable ratio.
Diesel till I die
Re: Signum ATF.
« Reply #13 on: 06 March 2024, 14:55:45 »
I dont know that particular gearbox, but I'd guess you'd get a little over half out, so end with a 50:50 mix os old and new.  After a 2nd change, that'll be 75:25, and a 3rd, 87.5:12.5 and so on...
Even 50:50 is a marked improvement on 100% old oil.
Re: Signum ATF.
« Reply #14 on: 06 March 2024, 14:56:19 »
LOL, snap. Typed at the same time ;D
Pages: [1] 2 3 4  All   Go Up
