Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Micksgarage and cheap wishbones  (Read 85903 times)
Re: Micksgarage and cheap wishbones
« Reply #45 on: 14 April 2024, 20:58:38 »
Yeah, worth keeping the GM wishbones for that very reason.
Unfortunately, you're stuck with whatever is currently fitted to the car, and 21 years after the last one was built they're highly unlikely to be the genuine ones.
« Reply #46 on: 15 April 2024, 10:35:44 »
Hence I always suggest people with GM ones refurb them, rather than replace with crap.  Its a bit extra work, but cheaper and will last longer.
Jim82
  • High Wycombe
    • Omega 2.6 Elite Estate
« Reply #47 on: 15 April 2024, 14:32:43 »
Is there any easy to spot tell tale that they are original GM? GM logo somewhere?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #48 on: 15 April 2024, 15:29:26 »
They'll look like they were rescued from the Titanic; rusty and covered in crap off the road. You're getting bogged down in details that are unimportant.
You've got new wishbones, so fit the front poly bushes and get them on the car. They'll be an improvement. If the removed ones look vaguely saveable, keep them. If they don't, bin them. To me, the only thing the originals do better than refurbished ones is that the ball joints are rivetted on, not bolted.
« Reply #49 on: 15 April 2024, 16:17:51 »
Also a moot point once they've been replaced as there isn't a single supplier of ball joints that supplies them with rivets.
And being bolted on actually makes them MORE serviceable, not less ;)
« Reply #50 on: 15 April 2024, 18:26:20 »
The balljoints usually last nearly forever, and the rear bushes are dirt cheap and readily available.  Once you fit the other shite, you lose these benefits.
Obviously, if you only plan on keeping it another 18 months, it's a moot point. As if somebody has already put pattern ones on.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #51 on: 15 April 2024, 20:43:47 »
To specifically answer your question Jim, the three rivits for the ball joint on original GM wishbones is a flat profile both sides, with a dimple in the centre on the upper side as a guide for drilling it out should the ball joint ever require replacing - all pattern / aftermarket wishbones seem to have domed rivets.
« Reply #52 on: 15 April 2024, 23:06:08 »
Every Omega I have ever owned has required ball joints, so not sure where you get that idea from. :-\
« Reply #53 on: 16 April 2024, 11:19:38 »
I’ve only ever had one genuine ballpoint fail. And I ran all mine on genuine wishbones, which just kept getting refurbed apart from the first time when I bought a pair (back when they were dirt cheap).
That’s where I get that idea from.
Virtually all of the shagged ball joints I’ve seen have been on pattern arms. Most of them the shit provided (when they can be arsed to post) by ATP
« Reply #54 on: 16 April 2024, 12:12:17 »
I thought that wishbones that had the harder polly bushes fitted had a tendency to crack  :-\ :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #55 on: 16 April 2024, 12:45:49 »
Only if you fit them to the back,
Hoof'land storeman.
« Reply #56 on: 16 April 2024, 12:49:19 »
Yeah, never found a workable solution to the rearward bush, other than replace with another rubber one.
Poly’d fronts are fine :)
« Reply #57 on: 16 April 2024, 12:56:49 »
Had no issues with Febi or Delphi ball joints fitted to aftermarket arms.
I didn't have the budget to spend £500 on wishbones so was quite happy to accept the life expectancy of cheaper arms and refurbish them as required.
This.
A vast improvement at the time, but only lasted about 7k miles. I don't recall the make of the wishbone that failed, but it could have been anything from GM to ATP special.
However, when fitted, those  rear polys made one hell of a difference to the way the car drove.
« Reply #58 on: 16 April 2024, 13:08:40 »
I knew there was something about polly bushes ..... it's been a while since my Omega days  :y
Jim82
  • High Wycombe
« Reply #59 on: 16 April 2024, 19:57:31 »
I was just curious really, if mine turns out to have GM ones on it currently I'll save them and refurb for next time.  If not, they can indeed go in the bin.
Pages: 1 2 3 [4] 5  All   Go Up
