Author Topic: SMETS2 smart meters  (Read 5714 times)
  • Auckland
    • Mazda MPV
SMETS2 smart meters
« on: 25 April 2024, 19:51:13 »
Finally got around to agreeing to have the meters replaced. Both gas and electricity were over 20 years old so 10+ years overdue.....
Waited all afternoon on Monday - no show.
Rescheduled for this morning - British Gas installer arrived and got on with swapping the meters.
Electrical meter swapped first and left to establish communications while the gas meter was swapped.
Gas meter swapped. Waited. Waited a bit longer.
I now have two shiny new dumb meters  ;D
    • Grandland 1.5 diesel
Re: SMETS2 smart meters
« Reply #1 on: 25 April 2024, 21:12:47 »
Octopus keep sending me emails telling me that both of my meters are past their certification, so I need to have smart meters installed. I keep ignoring them, let's see if they get bored.
Diesel till I die
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #2 on: 25 April 2024, 21:35:55 »
Same here with Eon, constant emails from them. The irony is that Eon did fit a smart meter in my house around four years ago but it only worked in dumb mode. I got a call from Eon recently saying that they needed to change the meter to a smart meter so I explained that my plasterboard is foil backed so they won’t get a signal, and that they’d already previously tried. They said ok and agreed to remove me from the mailing list but I’m getting more than ever now.  ::) ;D ;D
They also said, you can have the meter moved at your expense and I said that won’t be happening.  ::)
YZ250
« Reply #3 on: 25 April 2024, 21:44:52 »
The Eon fitter turned up and told me it would take him around ten minutes with the power off and he’d be sorted. Over two hours later he gave up, put the power back on and left.  ;D
« Reply #4 on: 25 April 2024, 22:02:53 »
To be fair, Auckland is a fair way for the British Gas installer to go between jobs.  :P                                      ;D
  • Auckland
    • Mazda MPV
« Reply #5 on: 27 April 2024, 22:31:13 »
Fair point.
We have smart meters in Auckland - they 'just work'. Probably because they have a good mobile signal.
I am back in Cornwall for a while - trying to clear up the chaos caused by people we trusted.  >:(
Each day I discover so many new things to piss me off that I have chosen not to share as I don't have the time :(
« Reply #6 on: 28 April 2024, 07:16:15 »
Fair point.
I guess you could have done without that, Andy. Life can be a pain in the arse sometimes, keep your pecker up mate.
Diesel till I die
« Reply #7 on: 28 April 2024, 15:48:29 »
And they will all need replacing again in the next decade or so, when 2G is sunsetted.
  • Auckland
    • Mazda MPV
« Reply #8 on: 28 April 2024, 22:20:18 »
I don't think 2G ever worked in this valley (despite the provider's signal predictions claiming otherwise). Does it count as sunsetting if it never worked in the first place :-\
Curious to see whether they can sort out the comms by adding an external ariel or 'mesh' communications.
My parents installed solar panels last year, To get the feed in tariff they needed a smart meter. The mobile signal in their house is even worse than it is here but Octopus went through the motions of fitting a series of comms modules until they got working comms so I expect that it should be possible here.
Why they waste time rather about with the basic comms modules in this area beats me, >:(
