Author Topic: AC Filler Valve Leakage  (Read 22680 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 02 May 2024, 12:56:55 »
Had today AC-service (Y26SE), checking leaks and changing the refrigerant liquid etc. All ok except we found that the lower filling valve in front of the car started to leak.
Took a closer look and found that the leaking one has not a Filler Valve (inner part) like the other in the rear. So in rear the valve is like a tyre valve or like part No. 6 in the enclosed pic. But the front one is just a hole. In the hole there is something which you can push and increase the leakage but leak does not stop when releasing. Acc. to 7zap I seem to have construction referred as part 2. I guess that in this construction the separate inner part really does not exist. Any experience about this? In the plastic protection gap there is a rubber seal, If I tighten it I think that the leak stops. Strange, do I need the whole Part 2 or did I understand this in a wrong way?
Jim82
  • High Wycombe
    • Omega 2.6 Elite Estate
Re: AC Filler Valve Leakage
« Reply #1 on: 02 May 2024, 13:13:32 »
You can replace the valve on its own, I think it's discussed on this forum somewhere.
Here's a link to the part available from Amazon:
https://amzn.eu/d/7TWwnJI
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 02 May 2024, 14:52:25 »
You can buy High side valves on eBay for £5.00,, the LP looks like a std tyre valve but uses a different seal, the seals are normally green.
Hoof'land storeman.
polilara
  • Finland
« Reply #3 on: 02 May 2024, 16:38:38 »
Hi, and thanks for comments, so...
1. Can I screw the valve informed by Jim82 directly to the existing one or do I have to replace the old one with it?
2. For biggriffin's idea I need perhaps some explanation or is the High Pessure valve just the valve Jim82 proposed, hope you can provide a link, this all is new for me...
polilara
  • Finland
« Reply #4 on: 02 May 2024, 18:59:14 »
Jim82
  • High Wycombe
« Reply #5 on: 03 May 2024, 10:05:58 »
https://www.omegaowners.com/forum/index.php?topic=124057.0
This I found.
That's the one  :y  Even my mechanic didn't believe you could change just the valve until I showed him the pictures from this forum  ::)
« Reply #6 on: 03 May 2024, 21:53:23 »
I understand that there is a specific socket for the valve, but I used a 15mm 12 point socket. Make sure you support the 17mm nut on the ally pipe underneath it otherwise you'll shear the whole fitting off. (won't he Jamie  ::))
« Reply #7 on: 04 May 2024, 08:47:14 »
I declare the 5th amendment ;D
polilara
  • Finland
« Reply #8 on: 07 May 2024, 19:50:01 »
So, Job Jobbed, installed new pressure side AC valve (actually needed ratchet with 8 corners. Filled again, no leaks and blowing cold air now. We have +3 degrees here now so cold air also in ECO mode..., thanks to OOF for all support.
