Author Topic: FL Manual transmission gaiter & handbrake gaiter change  (Read 14131 times)
mong00sehun
  • Hungary
    • 2.6 V6
Hi guys,
i bought the gaiter for my manual transmission and handbrake, but i dont have a guide for the job. Is there any guide out there?
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: FL Manual transmission gaiter & handbrake gaiter change
« Reply #1 on: 21 June 2024, 20:19:03 »
Not seen a guide but they just pull up don’t they.
The note below is from a previous thread on here :
Lift the base of the gear surround and pull up (so that the gaiter ends up inside out) there is a rubber o ring at the bottom of the gear knob, roll it down/off the surround and then pull surround off over the gear knob.  :y
The handbrake gaiter just pulls up doesn’t it.
YZ250
« Reply #2 on: 21 June 2024, 20:39:29 »
Still attached to its plastic frame obviously.  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 21 June 2024, 22:10:05 »
You will need a sharp blade(scalpel or single edge razor blade) and some impact adhesive.
The new gaiters usually come with a cable tie to close the ends, which is both bulky and ugly - replace it with a cord or some thin wire.
The new gaiters will need a little trimming to conform to the plastic surrounds before you stick them together.
It's a simple job that won't take an hour to do.
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #4 on: 22 June 2024, 19:48:26 »
before
https://cdn.rios.hu/dl/upc/2024-06/22/451739_ab5lkacogngulvp3_41502b89-5418-4fe7-a7eb-779705107bbf.jpg
after
https://cdn.rios.hu/dl/upc/2024-06/22/451739_mhtc6ifkw2vxboks_43043820-2aa2-4170-8c35-fb1b3d6fb322.jpg
it was not so hard, but i think the plastic "frame" around it, was not designed to change the gaiter anytime. Its a little rustic, but tomorrow will be the test, if it stays in place, then it will be okay. if not, i will have to use more glue  :D
« Last Edit: 22 June 2024, 19:50:07 by mong00sehun »
  • Chatham, Kent
« Reply #5 on: 22 June 2024, 22:35:34 »
That's much better :y
I was pleasantly surprised by the improvement to cost/effort ratio when I did mine.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #6 on: 23 June 2024, 10:50:17 »
That new gaitor looks very good indeed! You have done a good job :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #7 on: 23 June 2024, 19:59:05 »
before
after
Very nice job, makes all the difference.  :y
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #8 on: 23 June 2024, 22:25:12 »
thanks guys  :y
« Reply #9 on: 24 June 2024, 08:20:29 »
Yup, small jobs like that can transform the interior :y
