Author Topic: MOT for Caravans  (Read 3459 times)
Re: MOT for Caravans
« Reply #15 on: 15 September 2008, 12:40:05 »
 if the problem were as bad as is percieved, wouldn't insurers be pressing for a solution? ....
Some insurers make a service stap a stipulation of cover. But you don't legally require a separate insurance policy on your 'van.
You need it on the car, though, and I'm sure car insurance companies take a big hit when there's a serious towing accident.
« Reply #16 on: 15 September 2008, 12:41:39 »
Ah! I see what you mean now.  ;)  :y
« Reply #17 on: 15 September 2008, 12:45:40 »
AFAIK there is no requirement to inform the insurance company that you intend to tow, it is part of the coverage "by law" .... I have always told my insurers that I have a towbar fitted as a "modification", and that i use it regularly .. but they just ignore it.
Perhaps compulsory "trailer insurance" that the insurers could put "controls" on like no claim discounts, service criterea, weight limits etc etc would actually achieve more than an MOT which is only valid for the 15 seconds it takes the ink to dry.....
An MOT in January will have no relevance to a 'van/trailer that has been parked up unserviced but suddenly used the next October !!
Just my thoughts .. :)
« Reply #18 on: 15 September 2008, 12:51:14 »
My big issue is that there are loads of vans out there that are parked up for 6 months and then just taken on the road.
They need servicing at the beginning of each season and checking over as the tyres are often mega old (or even the wrong sort!) and the brakes tend to seize (and are fickle buggers to setup at the best of times) that plus chassis rot and the need to replace hub nuts following work means that many get VERY neglected.
Very recently a friend bought a pikey wagon and had the wheel fall off.....luckily they were just slowing down and were only doing about 10 mph or it could have been very nasty!
« Last Edit: 15 September 2008, 12:52:33 by Mark »
MickAP
  • South Derbyshire
« Reply #19 on: 15 September 2008, 12:59:28 »
Seen one or two incidents involving caravans and not all related to the state of the caravan or part of it. Some two cars I've seen have had a blow outs causing untold damage to the caravan.
A friend had two new tyres fitted to his caravan (on the advice of the service agent) before his trip to Devon. On the way back he had a blow out on one of the new tyres, and these weren't cheap brand jobs either.
I agree on a safety check or annual service for the caravan as in my opinion it's mostly tyres or hubs that fail, especially on older vans having been stood over winter.
Mine gets serviced annually and the tyres checked before each trip, what more can you do.  Stuff still happens on our roads that I have witnessed relating to bad driving and overloading etc.... how do you keep a check on that.
Mick
« Reply #20 on: 15 September 2008, 13:04:51 »
Fully agree Mark .. but an MOT won't prevent that  ... it might stop some of the 10 year old tyres and rusted through brake rods ... but it won't prevent siezed up things and numpty drivers.
The annoying thing to me is we regular users, who generally have the best serviced/maintained vehicles because we USE them ... get lumbered with the same reputation as the  "1 week a year" boys .. :(
BTW very few 'vans suffer "chassis rot" as they are mostly aluminium these days .. :)  floor delamination, side wall damp/rot,  corroded electrics .... yup .. but not "chassis rot" .......   ;D ;D ;D ;D ;D
« Last Edit: 15 September 2008, 13:05:45 by entwood »
« Reply #21 on: 15 September 2008, 13:14:32 »
In my personal experiences of attending accidents involving caravans the most common cause of accidents is human error. Be that in the form of poor loading, erratic driving or just plain old speeding! In fact, I would say that fewer than 1 in 10 was down to the poor condition of the offending van!
That said, I'm still willing to comply with a safety check as long as it was priced sensibly!  You only have to look at the official price of an MOT these days to appreciate that anything of that nature is seen as easy money by the powers that be :o :o
« Reply #22 on: 15 September 2008, 14:44:50 »
This is an issue, and as someone who occasionally tows 3 trailers that are seldom used if the cost to MOT each one got anything like as high as a car MOT I would not be happy. However, to cover the scope of "things that can ruin your day" it would only need to cover the hitch and safety devices, brakes, bearings, suspension, tyres, structure and lighting.
Of course, testing stations would need a special brake tester for trailers, etc. etc. so it would end up costly. It would also undoubtedly end up getting loaded with other stuff from the EU... gas installations, etc.
« Reply #23 on: 15 September 2008, 14:56:22 »
You would think that but, they went aluminium in the 90's and then went back to steel shortly after (some manufacturers) before going back to aluminium in the late 90's again.
Thing is, your looking to cover all braked trailers on the road....and some of them are right old nails (note I say trailers....)
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #24 on: 15 September 2008, 22:26:07 »
As someone who tows both a trailer, and a caravan, I personaly get my caravan checked bi-annualy, ie: gas/electric/water checked one year, and wheels/brakes/coupling/suspension the next, on a rolling basis.
The caravan gets frequent use from March through to October, before being 'laid up' on the forecourt, using 'winter wheel stands' and the wheels/tyres stored inside out of the way.
The trailer gets a lot more use, is only 5' x 3', but gets an annual 'check over' by myself, and a check over EVERY time I use it.
Having towed various caravans for over fifteen years, with a variety of cars, I have yet to have an accident. Most of the accidents appear to be due to incorrect loading, or innapropriate combinations of van/car.
Having a wife and children to consider, it costs so little to have checks done, in relation to the cost of an accident.
I pay £50 for a mechanical check, (brakes,suspension,coupling,chassis) and £60 for 'habitation' (gas, leccy etc) plus the cost of any parts, which to me, is a small price to pay for peace of mind.
Not sure if a MOT if the right way to go, but some form of paperwork to show that reasonable checks/repairs have been carried out/done seems a sensible way to go.
BTW, I informed my insurance company that I towed both a trailer, and a caravan, and they didn't seem bothered, but it may pay to let them know just in case..
I always knew I'd inherit an estate, but I never thought this would be it!
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #25 on: 15 September 2008, 22:44:05 »
My original though behind this was not to imply caravans were unsafe or driver by people that are not fit to tow, just to look at the safety aspect.
We are most likely different in our approach to cars and maintaining them due to our interest, not everyone shares our diligence, and the same could be said, i would imagine, for members of the caravan fraternity, and it is these that this test would be beneficial.
administering it and policing it could be a nightmare, but then so can clearing up he mess of one that has disintergrated  on a major A road or motorway.....
« Reply #26 on: 15 September 2008, 22:45:00 »
If you have your 'van serviced at an "Approved Service Centre" IAW the manufacturers schedule then a small sticker is placed on the side of the drawbar fairing.
I have seen Mr Plod checking 'vans and was stopped early this year (A38), they checked for the sticker .. looked inside (no loads down the middle of my vans), and wished me a safe jorney... :) Okay its a newish van, a decent towcar, and was obviously not overloaded. I think the 2008 service sticker helped.
Now I know a lot of folks think dealer servicing is a) a rip off, b) unneccessary, c) They'll always find "something" .... but I have to have it done as part of the warranty (so if they find any problems I don't pay for the rectification anyway . :) ) and £120 a year to safeguard my families lives and a £15000 investment seems reasonable to me.
« Last Edit: 15 September 2008, 22:46:07 by entwood »
