Author Topic: Rear fog lights.  (Read 11338 times)
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Rear fog lights.
« on: 14 December 2024, 16:35:47 »
They arent working. But telltale light on dash lights up ok. First two things that sprung to mind were a fuse and the wiring at the boot lid which can break down over the years with opening / closing of the boot.
two or three possible fuses, although Im pretty sure F28 is the correct one, but all fuses ok.
Traced the wiring from boot lid back into the car and it connects just above the spare wheel. Seems to be no power getting to the connector.
This is all on the assumption that the live wire is blue black and brown is 0v (earth).
Any ideas / info / knowledge appreciated.
Should have checked all lights a week ago, and then might have fixed the issue and not got an MOT fail. :-[
Re: Rear fog lights.
« Reply #1 on: 14 December 2024, 17:12:58 »
Grounding point is under the light in the rear quarter.
Also, and it's a stupid point but..., when you checked at the boot lid, you did have the headlights switched on?
Legally rear fog lights can only be switched on with either headlights or front fogs AND sidelights switched on.
Also, if it comes to it, the switches are interchangeable and removable from the main headlight switch so easy enough to swap out for testing purposes  ;)
« Last Edit: 14 December 2024, 17:16:03 by Doctor Gollum »
Migv6 le Frog Fan
  • Online Online
« Reply #2 on: 14 December 2024, 17:56:36 »
Not sure if the front fogs were switched on.  :-[
Back in a minute................ ;D
« Last Edit: 14 December 2024, 18:01:54 by Migv6 le Frog Fan »
Migv6 le Frog Fan
  • Online Online
« Reply #3 on: 14 December 2024, 17:59:25 »
Switched front fogs on, rears still not working.
Will check grounding point tomorrow in daylight. :y
If it isnt that, I will delve further, although if dash telltale comes on wouldnt that indicate the switch is working ?
« Last Edit: 14 December 2024, 18:02:57 by Migv6 le Frog Fan »
« Reply #4 on: 14 December 2024, 19:04:12 »
theres a plug/socket in the boot that would feed the rear fogs for a trailer  .... in normal use there should be a bridging plug  shorting the blue/black wire.
Its been a looooong while though since I've even seen an Omega  ???
« Last Edit: 14 December 2024, 19:15:42 by Andy B »
Migv6 le Frog Fan
  • Online Online
« Reply #5 on: 14 December 2024, 23:27:06 »
I have wiring etc. in there for the towbar, so will have a look at that, thanks Andy.
« Reply #6 on: 15 December 2024, 07:10:52 »
Depends on how the thing is wired. Diagram in Haynes will clarify  ;)
Migv6 le Frog Fan
  • Online Online
« Reply #7 on: 15 December 2024, 14:41:54 »
Just been out and had a quick play, checked earth, wiggled some wires, just before planning to use a meter to check ofr 12v along the circuit from the fusebox working towards the lamp cluster.
At some point during the wigglingof  wires, the fogs came on, and no amount of wiggling of wires would make them go off again.
That will do for me. As long as they light up when the MOT man checks them Im happy.
Cant remember ever using them anyway.  ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #8 on: 15 December 2024, 17:18:27 »
Don't they have fog in sunny Halstead?  :)
Migv6 le Frog Fan
  • Online Online
« Reply #9 on: 15 December 2024, 17:29:17 »
Imo its rare to have serious enough fog to use foglights amywhere in the UK.  :)
« Reply #10 on: 15 December 2024, 19:06:10 »
exactly .....
 but you know that at the very 1st sight of a little morning mist, you'll end up behind some numpty with their rear fogs on even though you can see 2 miles up the road!  :-X
    • Grandland 1.6 diesel
« Reply #11 on: 15 December 2024, 19:22:34 »
These days people drive with their front fogs on all the time. Look like a fickin spaceship coming down the road.
Diesel till I die
countrywoman
  • worcestershire
    • skoda yeti
« Reply #12 on: 16 December 2024, 09:21:58 »
Fine and points if you do!!!
« Reply #13 on: 16 December 2024, 11:42:59 »
Oh yeah?  ;D
Diesel till I die
