Author Topic: Bonnet support arms  (Read 26146 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Bonnet support arms
« Reply #15 on: 26 January 2025, 13:08:01 »
Well done Lizzie do you know if the boot struts are the same model as the bonnet ones.My front ones are on the way out and the boot ones are not much better.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #16 on: 26 January 2025, 13:46:09 »
No, they are different.
Part nos for the bonnet struts (all models) - 90379054
Part nos for the boot struts (saloon) - upto chass.no. X1999999 - 90379025, and from chass no. Y1000001 - 9146281
HTH
johnnydog
  • Lancashire
« Reply #17 on: 26 January 2025, 13:51:06 »
Incidentally, if yours is an estate, all models are also different again - part no. 90379081
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #18 on: 26 January 2025, 14:18:35 »
Thanks but confused my chassis no is Wolov BM6931082175
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #19 on: 26 January 2025, 14:22:47 »
When I bought new struts for my estate tailgate #-&^$% years ago, they were cheaper than the saloon ones! I suspect that's because they're a length that's usable in other general applications - they were aftermarket.
This sort of gas spring is so cheap it isn't worth not replacing them.
johnnydog
  • Lancashire
« Reply #20 on: 26 January 2025, 15:05:48 »
Assuming they are for your 2003 car, the Y****** on will be correct. :y
« Reply #21 on: 26 January 2025, 20:39:03 »
The difference for preand post facelift will be to allow for the differences between the two bootlids whereas ALL estates use the same struts because there's no difference between the tailgates.
« Reply #22 on: 27 January 2025, 09:23:01 »
I have an inkling that the FL bonnet struts are different to PFL/MFL ones as well, due to extra bonnet weight.
« Reply #23 on: 27 January 2025, 10:16:11 »
definitely different part numbers but I can't see they'd be that different  :-\
« Reply #24 on: 27 January 2025, 10:37:23 »
There's probably another 5 kg of weight, but it's right at the far end so there's a bit of leverage there.
Steveh
  • Debyshire UK
    • Omega 2L 16V
« Reply #26 on: 07 February 2025, 08:33:49 »
oh sorry you are now talking about ones for boot I could do with some myself
Jim82
  • High Wycombe
    • Omega 2.6 Elite Estate
« Reply #27 on: 07 February 2025, 22:15:56 »
The pre-facelift bonnet struts are 240N, the later ones are 290N
