Author Topic: Which oil for V6?  (Read 6091 times)
mong00sehun
  • Hungary
    • 2.6 V6
Which oil for V6?
« on: 24 February 2025, 13:36:46 »
Hi guys,
when i dont use the car for 1 or 2 days when i start it, i hear some lifter clicking for around 1 sec, and the lifters go silent.
I always used 10w40 semi-synthetic mobil1 oil. The hungarian omega group said, 5w30 is better for it, maybe prevents clicking too. Should i change?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Which oil for V6?
« Reply #1 on: 24 February 2025, 13:44:44 »
Either will do.
I used 10w40 in mine as it was cheaper, leaked less and was quieter than the one time I bought 5w30 by mistake. Plus, the other cars I worked on at the time also used 10w40
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #2 on: 24 February 2025, 13:55:38 »
I have used 10w-40 semi synthetic oil for years for all my Omega's, Carltons and a Senator without problem. :y
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #3 on: 24 February 2025, 16:00:50 »
I´ve used always 5w40 in my Omegas (2.2 and 3.0) with GM-LL-A-025, GM-LL-B-025 specifications or then Dexos 2. Numbers behind the oil can are as much important as the numbers in front ;)
Omega - when bad camber is actually a good camber
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #4 on: 24 February 2025, 16:13:11 »
Yes you’re in Finland so better a 5/40  than a 10/40👍
Laying a rubber road.
olm
  • spain
    • 3.2 v6 sport estate
« Reply #5 on: 01 April 2025, 09:04:39 »
I use Shell 5-40 and it works very well for the mayonnaise that these cars usually make, it practically doesn't make any and it uses a very good base.
