Author Topic: Cylinder Head Question.  (Read 72874 times)
Re: Cylinder Head Question.
« Reply #15 on: 23 April 2025, 07:59:38 »
Just skim it, if its measurable using standard kit then its an issue
« Reply #16 on: 23 April 2025, 09:25:58 »
It can't be skimmed. The issue is that no one knows what is an acceptable amount of distortion.
As I understand it, the reason it can't be skimmed is that the head is triangular with the timing cover attached to the block, head and cam covers so any deviation has the potential to make it impossible to reassemble and seal.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #17 on: 23 April 2025, 10:31:40 »
What was the main issue with it? Could having the head ringed sort it perhaps.
Laying a rubber road.
« Reply #18 on: 23 April 2025, 10:38:36 »
It's been overheated enough to melt the baffle in the water jacket.and the head gasket popped between 2 and 3.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #19 on: 23 April 2025, 12:27:49 »
Surely the cost of testing/machining would get you most of the way to a replacement head, that hasn't been cooked from the inside out  :-\
    • Grandland 1.5 diesel
« Reply #20 on: 23 April 2025, 12:42:00 »
It can't be skimmed/machined!
Diesel till I die
« Reply #21 on: 23 April 2025, 12:52:00 »
£80 to test it, but £2,200 for a new one.
« Reply #22 on: 23 April 2025, 13:05:46 »
Can you get a second hand head from a breakers?  ???
« Reply #23 on: 23 April 2025, 13:47:30 »
Christ!  :o :o
Viral_Jim
  • Telford
« Reply #24 on: 23 April 2025, 14:50:42 »
I 100% was not suggesting troubling Nissan, or anyone else for a brand spanking new one 👍
« Reply #25 on: 23 April 2025, 15:01:57 »
They will take quite a few thou, they won't have been made to that level of accuracy in the factory and the gaskets and sealant would take up the delta.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #26 on: 23 April 2025, 15:10:09 »
Petrol, possibly '68.
Poor cold starting followed by stalling upto temperature.
Full Nissan history from new.
Recently been in to investigate and found that the thermostat casing had split. Fixed and highlighted a misfire. All plugs found to be heavily fouled and replaced and car returned only to suffer poor starting again.
I suspect that the thermostat housing contains a coolant temp sensor and as the coolant dropped it misonformed the ECU causing it to over or under fuel. Resulting in the non starting and misfiring.
Is the above a reasonable diagnosis?
Three weeks later and the thermostat housing has failed again.
Quote above copied from your original thread.
As my daughter-in-law has a 2019 petrol Qashqai I thought that I'd best look into this. It appears to be more common than it should be, so much so that the thermostat design has been changed. Some that are out of warranty but have suffered the head gasket issue as a result are trying the legal route against Nissan, stating that it must have been a known issue for Nissan to change the stat housing design.
YZ250
« Reply #27 on: 23 April 2025, 15:29:16 »
« Reply #28 on: 23 April 2025, 15:47:49 »
One source of same issues here.  :y
https://www.qashqaiforums.co.uk/viewtopic.php?t=13191&start=20
Apparently Mercedes now fit a bracket to the housing to prevent it separating. Which is the cause of the issue, compounded by a lack of coolant level warning. Which is, er,. suboptimal given that the coolant capacity makes a K series look over filled.
« Reply #29 on: 23 April 2025, 15:49:00 »
Second hand is circa £350/400 and likely to be just as buggered.
Pages: 1 [2] 3 4  All   Go Up
