Author Topic: Cylinder Head Question.  (Read 72872 times)
Re: Cylinder Head Question.
« Reply #30 on: 23 April 2025, 15:50:43 »
Surely the cost of testing/machining would get you most of the way to a replacement head, that hasn't been cooked from the inside out  :-\
£80 to test it, but £2,200 for a new one.
Actually they didn't charge out of pity.
The verdict:
0.18mm so basically a stupidly shaped door stop.
« Reply #31 on: 23 April 2025, 16:04:28 »
7 thou" ??? I think I'd still go for the skim .... there's nothing to loose other than the cost of the skim
« Reply #32 on: 23 April 2025, 16:09:20 »
It can't be skimmed. The issue is that no one knows what is an acceptable amount of distortion.
As I understand it, the reason it can't be skimmed is that the head is triangular with the timing cover attached to the block, head and cam covers so any deviation has the potential to make it impossible to reassemble and seal.
They will take quite a few thou, they won't have been made to that level of accuracy in the factory and the gaskets and sealant would take up the delta.
If you can provide the engineering drawings to confirm the factory tolerances then happy days.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Laying a rubber road.
« Reply #34 on: 23 April 2025, 19:44:23 »
Not sure how that would keep the water in. :-\
It's already an MLS gasket fwiw.
« Reply #35 on: 24 April 2025, 08:08:22 »
Unlike you, I have spent enough years in engineering design to know dam well that the parts on that engine will not be machined to a tolerance that would not tolerate a fraction of a millimetre mismatch. If you were to add up the tolerance of all the mating items they will easily be closer to the 0.5mm level.
Raeturbo
  • South Wales
« Reply #36 on: 24 April 2025, 10:51:48 »
   It would keep the water out of the combustion chambers if that was the fault
    • Grandland 1.5 diesel
« Reply #37 on: 24 April 2025, 12:10:54 »
Don't let him get to you, Mark, you know what he's like.  ;D
Diesel till I die
« Reply #38 on: 24 April 2025, 21:52:30 »
I suspect that it was more the result rather than the cause. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #39 on: 24 April 2025, 21:59:04 »
As Mark says,any head can stand a 7 or 8 thou skim,let's be honest  here,a new head basically scraps the car when added to the parts list and the new head casting is probably bare so more work/ parts being needed
other rides
« Reply #40 on: 24 April 2025, 23:10:38 »
Thank you for clarifying that. Unfortunately the actual tolerances are apparently a closely guarded secret, which when coupled with the fact that the official line is that the head must not be resurfaced perhaps explains why the place that tested it won't even entertain resurfacing it.
« Reply #41 on: 25 April 2025, 07:08:34 »
I've lost count of the number of engine manuals I've read that say the head can't be skimmed. It's just @rse covering, surely?
I the face of F-all to lose I know what I'd do.
« Reply #42 on: 25 April 2025, 07:35:17 »
I've a 4k mile head on the way for less than the cost of skimming it, Notwithstanding that they wouldn't skim it anyway. ;)
« Reply #43 on: 25 April 2025, 10:46:27 »
They'd do as they were fickin told if I was paying for it. Them or someone else.
Diesel till I die
« Reply #44 on: 25 April 2025, 10:57:04 »
It's a moot point.
Pages: 1 2 [3] 4  All   Go Up
