Author Topic: washer non return valve  (Read 16145 times)
« on: 16 May 2025, 12:32:41 »
OK, so looks like Betamax Man has struck again, as I'm struggling to find a non return valve for the car's washer system.
ID of tubing is 3.2mm near the washer jets, which is where I want to fit them, after it flows through something like https://www.ringautomotive.com/en/product/RWC4
Re: washer non return valve
« Reply #1 on: 16 May 2025, 12:41:06 »
Air pipe fitting from a tropical fish tank, air pipe non return maybe do the trick.
« Reply #3 on: 16 May 2025, 13:00:16 »
Which is fine until you want a 3.2mm one ;D
There are one of 2 about, but are physically too bulky as they have a 1" middle section.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 16 May 2025, 13:16:59 »
Durite 0-593-07.
Try the nearest place that sells truck parts as you can't be trusted to use Ebay :)
Or you could try something like THIS
« Last Edit: 16 May 2025, 13:20:28 by Nick W »
« Reply #5 on: 16 May 2025, 14:37:25 »
Durite 0-593-07.
Both those are for 4/5mm tubes Nick W, I've found a million and one of those.   I've tried to get the tubing over, but it aint having any of it despite warming the pipe
« Reply #6 on: 16 May 2025, 14:47:53 »
For clarity, it need one with the OD to be around 3.2mm (the barb will be a bit bigger, obviously).
Againt I can find loads claiming to be 3.2mm, but the is the valve's ID, with the OD being the more standard 5mm.
« Reply #7 on: 16 May 2025, 15:22:32 »
Presumably Jaaag CBA to supply them. :-\
« Reply #8 on: 16 May 2025, 16:51:18 »
Do Land Rovers/Range Rovers have the same part?
« Reply #9 on: 16 May 2025, 17:26:09 »
I suspect it's because of the sh1te design of their headlamp washers and the fact that they don't bother as standard that he wants them. ;)
Which reminds me...
« Reply #10 on: 16 May 2025, 19:54:42 »
They can, but its well known JLR's suppliers can't supply a plastic part that lasts more than 10s
« Reply #11 on: 16 May 2025, 19:55:18 »
Can't find a cross ref LR part number....
« Reply #12 on: 16 May 2025, 19:55:51 »
Although it would still be the same shit part from Belgium.
« Reply #13 on: 16 May 2025, 19:57:38 »
Is that better or worse than a shit part from China?  :-\     ;D
Talking of which have you tried Temu?  :D
« Reply #14 on: 16 May 2025, 19:57:53 »
Which reminds me...
Screen washing.  It's a combined T-piece and valve, and is monumentally shite.
Made 10 times worse that the XJ gives 2 quick squirts on the upstroke of the wipers, so can be up to the 3rd attempt before I can get water....
