Author Topic: 3.2 Running issue  (Read 61915 times)
3.2 Running issue
« on: 22 May 2025, 15:07:50 »
My 3.2 has covered the last 10k miles without missing a beat, including a trip through France and Spain down to Gibraltar.
Last night, SWMBO was driving it, stopped to call me at a garage and said it was "holding back".
This morning I went out for a look. Plugged in the code-reader, and there was one "pending" code for Short Term fuel trim - bank 1.
Tried to start the car, quite a bit of turning over and then it fired. I left it to idle, and it was hunting... revs going up and down consistently on their own. Not misfiring though.
Took it for a drive, went ok through the village although felt underpowered. Got to a bigger road and gave it some more throttle, and it completely bogged down, with the throttle down hard, there was no power at all, but as soon as I eased off, it would gently cruise. I did on a couple of occasions managed to get it to rev much higher, but it won't do it every time.
Compressions are all good.
Plugs all good.
No code 19.
No recent work on the engine in the last 10k miles, so nothing recently disturbed to introduce any big air leaks. Vac / servo pipes and bagpipes / trumpets etc all in place correctly.
I am now thinking fuelling issue? Pump in the tank?  I don't think these are clever enough to give a live data fuel reading, as no sensor on the rail, is it worth me getting a manual fuel pressure testing kit? This may make it awkward to view it whilst under load - which is when the symptoms are most evident.
Any other suggestions please? I did once look at a car for a chap with similar symptoms and he was tearing his hair out, turned out there was something large and dead in the air intake - so that's worth a look too I guess! :y
Re: 3.2 Running issue
« Reply #1 on: 22 May 2025, 15:09:14 »
When I put the foot down and nothing happened, it felt JUST like running out of fuel.....  I should add, tank is half full. And no, she hasn't put diesel in it  ;D
« Reply #2 on: 22 May 2025, 15:24:41 »
You'll never get a 2 digit code off a DBW car.
Any improvement with the MAF unplugged?
Weak/failing fuel pump would cause that type of behaviour.
« Reply #3 on: 22 May 2025, 15:55:24 »
Yes sorry I know it’s a 4 digit on DBW  - I just meant the equivalent code in old money :y
No different with MAF unplugged
For some months it’s misfired upon cold start but then clears immediately if turn off and back on
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 22 May 2025, 17:38:41 »
Fuel filter ?  :-\
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 22 May 2025, 18:45:06 »
Fuel tank pump getting lazy or pipes deteriorating in tank?   :-\
« Reply #6 on: 23 May 2025, 12:19:54 »
Live data it. Are the trims bad on both banks?  In particular, are the LTFT's moving off 0%.  If just on one bank, look for air leaks only impacting that, on both intake and exhaust, but also don't rule out the primary O2 sensors itself on that bank. If both banks, look for leaks that impact both banks, or MAF.
MAF at idle should be around 12-13kg/hr for a 3.0/3.2 with A/C off. Add around 1kg/hr if your A/C still works and is on.
« Reply #7 on: 23 May 2025, 13:56:36 »
Thanks TB, I did look at the data values, LTFTs appeared fine from memory, and the MAF readings around about 12kg/h :y
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #8 on: 23 May 2025, 16:51:33 »
A vacuum gauge could help here👍
Laying a rubber road.
Raeturbo
  • South Wales
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #10 on: 24 May 2025, 13:09:28 »
not sure how it compares but mine runs at 2.5 g/s although its a 2.6
« Reply #11 on: 25 May 2025, 09:01:41 »
g/s x 60 x 60 / 1000 = kg/hr
So in your case, that's 9kg/hr which is slightly on the low side of OK - a 2.5/2.6 is usually around 10-12 with a/c off
cam.in.head
  • West yorkshire
« Reply #12 on: 25 May 2025, 11:36:24 »
doesnt seem go have any issues. mpg is good ,runs find and mot emmidions are fine but i will look into if theres any air leaks as the ltft's are on +2.5 ish . cheers .
as regards the posters issue definately worth doing a fuel pressure check as it does sound fuel related
« Reply #13 on: 25 May 2025, 15:54:15 »
That is a issue assuming it's not LPG converted
cam.in.head
  • West yorkshire
« Reply #14 on: 25 May 2025, 18:46:09 »
well this is typical of my luck !   i comment on someones post and end up finding out my own car has a problem i didnt know existed . i was always under the impression that up to 10% ltft was normal . think i even read it on here somewhere over the years . whatever it is its obviously not a major fault as the car runs absolutely fine . rock steady idle ,mot emmisions spot on and fuel consumption is ok too ( not that i have owned another 2.6 to compare it to )so i wont be worrying too much but if its supposed to be zero ltft il investigate a bit !!
