Author Topic: Dtc u2100 and 2108  (Read 10454 times)
olm
  • spain
    • 3.2 v6 sport estate
Dtc u2100 and 2108
« on: 29 May 2025, 04:19:49 »
Hello everyone.
I've recently been seeing these fault codes intermittently. The ABS and TCS lights come on, and the speedometer stops displaying.
It seems to be a CAN bus issue. Could it be the ABS sensor that measures speed, or should I look at something else?
Thanks.
Re: Dtc u2100 and 2108
« Reply #1 on: 29 May 2025, 14:20:53 »
Now about to look up codes currently, but what codes are in the gearbox and abs ecus?
olm
  • spain
« Reply #2 on: 29 May 2025, 17:02:35 »
None, only those DTCs appear. It's manual
« Reply #3 on: 30 May 2025, 14:01:08 »
Is your reader capable of reading ABS, or is it only a generic OBDII reader?
olm
  • spain
« Reply #4 on: 01 June 2025, 12:47:00 »
It's a Delphi system, but it can't find anything in the brakes section. Now I've seen P0500, which is the speed sensor. Could you tell me which sensor it is? I imagine it's one of the ABS sensors?
« Reply #5 on: 01 June 2025, 14:25:11 »
You need to read the ABS system to discover what is causing it, and if it is one of the ABS wheel sensors.
The engine ECU complaining about road speed will be a sign the ABS isn't happy with something, but you do need to interrogate the ABS to find out what.
olm
  • spain
« Reply #6 on: 01 June 2025, 17:09:47 »
Wow, I can't find anything in the brakes section. I'll ask a friend who has an Autel machine to see if that one can read it.
« Reply #7 on: 01 June 2025, 21:02:09 »
0500 is a general fault. The specific sensors will have a number allocated to them 0xx1, 0xx2 etc
olm
  • spain
« Reply #8 on: 07 June 2025, 03:39:11 »
Thanks, my friend told me he also has the O P com,   let's see if I'm lucky and can see it
« Last Edit: 07 June 2025, 03:41:24 by olm »
« Reply #9 on: 07 June 2025, 19:29:56 »
That reader should be able to interrogate the ABS.  You can also view live data off each sensor with that, by going into "Measuring Blocks"
