Author Topic: Shudder when dipping clutch or accelerating hard  (Read 8535 times)
Carbine
  • West Sussex, UK
    • 04 TVP 3.2 Traffic Car
« on: 21 June 2025, 16:35:40 »
Hi everyone,
My 3.2 manual shudders when I dip the clutch, or blip the throttle, especially prominently between gear shifts. Feels as though engine mounts are worn?
Can anyone recommend if there's any in particular that I should change to rectify this, and have shifting feeling more positive and smooth?
Thanks.
2004 ex-TVP Omega 3.2 Special Traffic Car - OU04 NDF
Re: Shudder when dipping clutch or accelerating hard
« Reply #1 on: 22 June 2025, 00:41:26 »
They don't take kindly to rushed shifting. Lift off. Clutch in. Shift. Clutch out. Throttle. 0-60 is sub 7 seconds without trying to rush it. Trying to speed match the shifts just baulks the gearbox. In my experience.
Could be an indication of the DMF beginning to fail.
« Reply #2 on: 22 June 2025, 03:12:07 »
Or a sticky release bearing. But it's one of those jobs where you should replace the lot.
Be warned though, the last 3.2 flywheel I bought from VX was nearly a grand. The clutch kit itself is relatively cheap and fitting it is an easy couple of hours on a lift.
It is drive way doable but it's a bear to lift it high enoughto get the box out.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #3 on: 22 June 2025, 08:33:34 »
Two engine mounts in the bay are accessible with long extensions and a socket.
Worth getting it on a ramp and giving all the transmission mounts a prod and check they're done up tight. Under the box is a big rubber mount that can split, then the mounts under the prop and around the diff, too. Rule that lot out before you start unmantling anything fiddly.
Carbine
  • West Sussex, UK
« Reply #4 on: 23 June 2025, 10:08:08 »
Thanks both.
I'd expect it's still on original engine mounts at 125k miles, so I'm sure that's where the play is coming from. I'll. Have a closer look when I can get it to a ramp.
« Reply #5 on: 23 June 2025, 10:41:00 »
If the engine mounts separate you'll know the second you throw it through a tight roundabout... You'll literally feel the weight of the engine move. They get destroyed by persistent oil leaks.
