Author Topic: Omega X25XE Oil pressure light flickering at idle  (Read 7969 times)
csepet
  • Magyarország
    • Omega 2.5 V6, Golf 4 PD
« on: 24 June 2025, 05:52:46 »
Hi!
I recently started reviving a 1998 2.5 V6 omega with 170k kms as a project car.
After a lot of work i got the car up and running pretty nicely, however after my first longer drive in it i noticed that the oil light flickers at idle when the car is really hot.
It has new:
-oil (5W-40)
-oil filter (newer cartige style), oil press pressure sensor
What are the common couses of this? I doubt its excessive engine wear as it sound really nice, however i do know that is was neglected for about 4 ish years before being parked in 2012.
I have read that the relief valve could get stuck but where do i find that?
Re: Omega X25XE Oil pressure light flickering at idle
« Reply #1 on: 24 June 2025, 08:16:19 »
It's built into the oil pump. Worth dropping the sump pan and checking the pick up strainer for and debris.
Also you might try 10w40 :y
« Reply #2 on: 24 June 2025, 08:59:39 »
As Doctor Gollum suggests, check the oil pickup (which is always worth doing, despite the slight mess and hassle - plus you can clean the sump out at the same time - and consider using a slightly thicker oil.  10W40 Semi Synth was the original spec for that age Omega.
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #3 on: 24 June 2025, 20:18:44 »
bojler elado  >:D idovel elmeletileg tud degradalodni az olajpumpa, de nagy esellyel nem errol van szo. volt egy post nemreg egy 3.0-rol ott is hasnolo volt az eset, lehet hogy a homerseklettel osszefugg? (nyar)
as https://mymotorlist.com/ said, the oil pump can degrade over time... there was a 3.0 with similar problem maybe you can get some info from it: https://www.omegaowners.com/forum/index.php?topic=151576.0
csepet
  • Magyarország
« Reply #4 on: 30 June 2025, 05:16:52 »
Thanks for the help, cleaning the sump was the right call. The bottom of the pan had around 2 milimeter thick layer of jellyfied oil, but i think the issue was caused by the pickup being blocked partially by the jellyfied oil and the o ring for the pick was also extremly flat. Anyway the issue seems to be resolved.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 30 June 2025, 13:22:38 »
Good news.  :y
