Author Topic: Can you identify this transmisson?  (Read 8751 times)
mong00sehun
  • Hungary
    • 2.6 V6
« on: 07 July 2025, 18:43:45 »
Hi guys,
I found this transmission on facebook, the guy said its from 3.0 V6.
Can you help me with the identification?
Is this an R30 transmission? https://www.opel-infos.de/technik/getriebe/r5.html says: also on the R30 it says "R25-R28"
Re: Can you identify this transmisson?
« Reply #1 on: 07 July 2025, 21:57:49 »
It's a 5 speed manual. The casing is used to house the various internals and is a bit misleading. The R number refers to the torque range, not the engine size.
Basically the only certainty is that it's a manual gearbox from an Omega. If that's what you're needing, that's what you have. :y
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #2 on: 07 July 2025, 23:00:54 »
can i use this gearbox with my Y26SE? what modification i need if i need any?
« Reply #3 on: 08 July 2025, 06:12:59 »
If it's already a manual, then it's a straight swap.
If it's an auto, then you need everything to make it manual.
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #4 on: 08 July 2025, 13:17:02 »
yes its manual
thanks for the help  ;)
